Alternate Print Surfaces smiling smiley Skate Board Grip Tape
February 12, 2013 10:47AM
Hi All,
Anyone have any ideas for alternate print surfaces?
I have printed on blue-painters tape, kapton, glass and aluminum with success and failure on a case by case basis. Heated blue tape is definitely my "go to" method.
I was recently considering printing on skateboard style grip tape. I was thinking that perhaps a mesh pattern could be laser cut into the grip tap, so that some of the printed object is on the tape and some of the print touches glass.
In my mind, this would last longer than blue tape, grip the print very strongly, yet actually be easy the print once bed heat is removed (the print would release from the places where it touches glass)
I would love to hear any ideas you have for alternate print surfaces. The afina printer has a unique surface. Though I am not sure exactly what it has. Can anyone elaborate?
Edited 1 time(s). Last edit at 02/12/2013 02:22PM by Idolcrasher.
FabberForge - Printing Happiness
[www.fabberforge.com]
Re: Alternate Print Surfaces smiling smiley Skate Board Grip Tape
February 12, 2013 11:43AM
Hello,
The only problem i can see is an abrasive problem.
A Z axis to low and you can go buying a new nozzle :-\
But the idea of rought surface is not so bad... Maybe small sandpaper (1200/800gr) can work.its a little less abrasive.
February 12, 2013 12:13PM
Idolcrasher Wrote:
> I would live to hear any ideas you have for
My current fad is heated mirror-glass with hairspray at the print surface, seems to work well for PLA, and it's easier to remove parts than using watered down PVA glue on Glass, and easier to clean than PVA.
I believe the Afina (UP!) uses a fiberglass perf board (PCB material) - mechanical and some bonding to hold it down, but I believe they also still use a raft for every print, the raft then just bonds itself into the perf board.
[richrap.blogspot.com]
February 12, 2013 02:04PM
To clean PVA I squirt the platform with a spray bottle and spread it around with my finger.
February 12, 2013 08:26PM
ABS and PLA will both stick to a PCB material?
February 13, 2013 02:48PM
Not to my knowledge. The UP uses a board with a lot of tiny holes in it. First it prints a raft which fills the holes and stick mechanically.
February 13, 2013 05:01PM
Perhaps grip tape with many tiny laser cut holes would be killer great smiling smiley
Edited 1 time(s). Last edit at 02/13/2013 06:59PM by Idolcrasher.
