Layer Consistancy
Posted by N314
Layer Consistancy
February 17, 2013 01:26PM
The left is from my printer with a .35 nozzle( few months ago). It had very good layering, [Besides Z wobble]... But it was smooth. The one on the left is recent [last night]> My printer no has a .25 nozzle. Z wobble is not what im asking, I will fix that. But why are the layers now inconsistent? Please help.
My filament is ultimachine so its good.
My hobbed bolt is clean and round.
-Nick
open | download - DSC_2616.JPG (567.8 KB)
Re: Layer Consistancy
February 18, 2013 03:26AM
unequal pressure. go into configuration.h and change z steps per mm to be within 100ths and that is it. so 2555.6677 should be 2555.66 for example. any settings above 3 digits past decimal can cause a calculation error because of single precision floats ieee 754 [en.wikipedia.org]
once that is adjusted, calculate flow rate down until it disappears, or you are satisfied. for that matter also setting up x y with accuracy down to the 0.001 would help as well.
errors are multiplied for each movement required from 1mm to 200mm with same number , then after multiplied by actual number, are rounded and truncated down to floating point. the error can be substantial and is base on how far the error needs to be rounded off. this error in z squeezes the filament layers closer together, and in x/y errors cause slightly longer motion per move causing thinning of filament.
February 18, 2013 09:48AM
Will try adjusting firmware tonight. Ill hope for the best.
Just round X and Y steps to nearest Hundredth?
What do you mean calculating flow rate? Is there a place for that in the firmware?
Thank you.
-Nick
February 18, 2013 10:41AM
Out of curiosity, wouldn't you want 2555.67?
February 28, 2013 10:33AM
actually i think precision is 5 digits, as you go further out the rounding gets worse and worse. so actually to 10ths is better for z axis 1/100 seem to work as well. the idea is to have it always move the same amount of steps and not round off much. you would rather have a margin of error in the entire print size vs uneven steps in z axis for visual appeal.
Edited 1 time(s). Last edit at 02/28/2013 10:34AM by jamesdanielv.
February 28, 2013 12:05PM
> floats ieee 754
What is this supposed to accomplish? The number gets rounded into the float when the firmware is compiled in any case. Dropping decimals by hand can only reduce the accuracy.
February 28, 2013 01:21PM
I have done it and it's night and day with 1/4" ACME screws.
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
February 28, 2013 08:21PM
Remember that the precision is just a few digits, and that the float is multiplied once more by firmware which often increases digits further, and then stored as a float again. This is where the bigger error in data happens, when the float is multiplied further. With z axis the issue is there are so many places to the left of the decimal to start out with.
It would be best to later on convert firmware to a double long 64bit integer for z axis. There already are 64bit math alternatives out there. They should also process faster than floats.
I see z ,e axis as a must and x,y couldn't hurt either.
Edit: and further discussion of this should probably move to a firmware area of the forum.
Edited 1 time(s). Last edit at 02/28/2013 08:24PM by jamesdanielv.
March 01, 2013 09:08AM
Z wobble will also result in layer thickness changing in each layer if it causes the carriage to actually move up and down. Whether this happens depends on the design of the z axis. This is a very common problem with the Ord Bot due to the flex in the z motor plate. I suppose, this can also happen on a Prusa if the motor is not fixed well vertically or if the coupling allows for up and down movement.
I find it hard to believe that the number of decimal places in the steps per mm specified in the configuration.h would cause this. If it does, then someone should rewrite the firmware code.
March 01, 2013 09:19AM
well give me a few days and I'll give you an picture example. all I'll change is the firmware values for z axis. it is more likely with imperial measurements rather than metric hardware. metric hardware ratios are more closely matched, however issue will still occur if you do a height of 0.125mm for example instead of 0.1mm or 0.2mm.
March 01, 2013 09:35AM
At 1/16 steps, an M8 threaded rod gives 0.000390625 mm/step, a 5/16-18 threaded rod gives 0.0004410 mm/step. Even if the calculation is off by a few steps, the change in layer thickness won;'t be significant. at a layer thickness of 0.25 mm.
March 01, 2013 10:01AM
brnrd you are thinking with numbers that are precise. think about a float
0.000390625 becomes
3.90625005820766091346740722656E-4 float
[www.binaryconvert.com]?
March 01, 2013 08:38PM
And why would that amount of error be a problem?
March 01, 2013 10:19PM
OK.
I changed the Z-steps in firmware from 2035.5809493712193 to 2035.6
2 prints
Same Gcode
No mechanical changes, 1/4" ACME screws
Same plastic
I think the image below speaks for itself.
[i.imgur.com]
- akhlut
March 01, 2013 11:01PM
akhlut Wrote:
> OK.
> 2 prints
> Same Gcode
> Same plastic
> [i.imgur.com]
no shit? wow.. So one or two decimal places for z-steps. What about x,y, same thing?
March 01, 2013 11:07PM
No, X and Y remain the same.
- akhlut
March 01, 2013 11:24PM
Your corners will be a little cleaner by also rounding off the e axis to 10ths or 1/100th max. It is a little bit harder to prove, but it is on the same principle.
I think the issue may be with how iround is used to convert number in the firmware, and the way it is done exponentially increases the error before rounding. Investigation continues.
March 01, 2013 11:52PM
2035.6 microsteps/mm? Wouldn't that mean your acme threads are 2035.6*25.4/200/16=16.1577 threads per inch?
I'd have guessed that 1/4-16 threads would need 2015.748 microsteps/mm, (or maybe 2016.0 steps/mm for 1/4-16.002 threads)
What layer height are your using?
2035.6 microsteps/mm * 0.1mm = 203.56 microsteps/layer
2035.5809493712193 microsteps/mm * 0.1mm = 203.55809 microsteps/layer
Seems like it would take 25 layers or so to stack up a rounding difference worth a microstep.
March 01, 2013 11:56PM
Printing a part now. Will cut down e to 100ths and re-print.
I'll post a photo of the difference when complete - tomorrow morning. smiling smiley
- akhlut
March 02, 2013 01:37AM
Yes, they are 1/4"-16 screws.
I would have guessed the same thing ~ 2016 steps/mm, but I guess they're not perfect. After all, they're cheap screws from mcmaster. And I haven't done a teardown of the machine to justify upgrading to 10mm trapezoidal screws - after all that would mean new x-ends, etc. Just have other stuff going on that I can't justify it.
As far as layer heights are concerned I'm using 0.1905mm - I realize that is outside the bounds that slic3r is capable of (1000ths), but it was either accept that level of imprecision or step up to 0.254mm layers. I'm trying to hit full-step layer heights.
Also, 400 step motors @ 1/8th, not that this should matter.
I attached the calculator spreadsheet I made/used.
- akhlut
open | download - Steps Calculator.xlsx (219.1 KB)
March 02, 2013 10:37AM
OK
Silver part printed @ 927.19
Red part printed @ 927.1899669966999
Personally I think the silver part looks worse.
- akhlut
March 02, 2013 04:28PM
thats good info to know. it keeps the focus on the z axis. thanks!
March 02, 2013 05:42PM
@akhlut: I guess, that the effect may depend on use of absolute coordinates on extruder axis. Do you use absolute or relative?
March 02, 2013 07:58PM
@ miso, absolute. I've never used relative...
- akhlut
March 02, 2013 08:26PM
akhlut Wrote:
> OK.
> 2 prints
> Same Gcode
> Same plastic
> [i.imgur.com]
Z wobble. The problem with this test is that z wobble comes and go. So, the difference probably has nothing to do with the change in z steps per mm.
March 03, 2013 01:29AM
Would you like me to re-produce it? I'm fairly sure that I can by changing the Z-steps in firmware.
Also, I think that Z-wobble is pretty improbable. I've got 10mm chromed smooth rods on Z with sintered bronze bushings,which provides a nice, snug fit. Add to that the drive screw is as unconstrained as possible from the X-end as there is a decoupler with a pair of teflon washers between it and the X-end.
I've also changed out the coupling to something like this, which works very well.
But I find it incredibly un-likely since the "wobble" has disappeared since the change to firmware...not to say that it won't re-appear, it just hasn't yet.
- akhlut
March 03, 2013 11:12AM
Well ive changed the Z steps... Im not SURE if it made a difference, but they look nice.
Im still suffering Z wobble, ive tried many things to fix it. How havy you guys tackled it?
-Nick
March 03, 2013 01:04PM
What size are your Smooth and Threaded Z rods?
- akhlut
March 03, 2013 05:07PM
I assume you have a prusa? If so, have you checked that your z motors are screwed down firmly? Any slight movement in the motor position will badly affect your layer consistency.
March 03, 2013 05:31PM
wobble is also from z couplers having no give, and loose bushings on the zrods. zip tie down the z axis bushings to the x-motor and x-idler that have bushings on the z rods.
this firmware issue is still being looked into. I would guess that debugging the output and showing difference in steps would be the absolute proof it is also happening from some sort of internal error in the hardware.
