Move Z to top
Posted by KelOfTheRockies
Move Z to top
February 24, 2013 07:02PM
Does someone here know what Gcode command will move the Z axis to the top? I'm not looking for homing, that moves my Z to the bottom. I want a single command to move Z up to the nozzle where a print would start - Z Max in the firmware
Thanks!
- k -
Re: Move Z to top
February 24, 2013 07:52PM
G1 Z0 should always put the nozzle on the bed. A print normally starts by moving to one layer height above the bed though.
If you home away from the bed it should home to Z MAX, so Z = 0 is still at the bed.
To go to Z MAX do G1 Z999 and the soft limit should stop it a ZMAX but that should always be where the nozzle is furthest away from the bed.
Re: Move Z to top
February 24, 2013 08:52PM
Thanks Nophead, The Z0 command was what I was looking for.
I appreciate your help!
- k -
