ATX power supply and Sanguinololu controller March 01, 2013 10:46AM |
Re: ATX power supply and Sanguinololu controller March 01, 2013 11:36PM |
Re: ATX power supply and Sanguinololu controller March 02, 2013 12:42AM |
Re: ATX power supply and Sanguinololu controller March 02, 2013 12:54AM |
Re: ATX power supply and Sanguinololu controller March 02, 2013 02:30AM |
Re: ATX power supply and Sanguinololu controller March 02, 2013 09:10AM |
Re: ATX power supply and Sanguinololu controller March 05, 2013 10:28AM |
Re: ATX power supply and Sanguinololu controller March 05, 2013 02:09PM |
Re: ATX power supply and Sanguinololu controller March 05, 2013 11:57PM |
Re: ATX power supply and Sanguinololu controller March 06, 2013 01:31AM |
Re: ATX power supply and Sanguinololu controller March 06, 2013 06:19AM |
Re: ATX power supply and Sanguinololu controller March 06, 2013 12:19PM |
Re: ATX power supply and Sanguinololu controller March 06, 2013 01:40PM |
Re: ATX power supply and Sanguinololu controller March 06, 2013 03:44PM |
Re: ATX power supply and Sanguinololu controller March 06, 2013 04:38PM |
Anonymous User
Re: ATX power supply and Sanguinololu controller March 16, 2013 10:48PM |
Re: ATX power supply and Sanguinololu controller March 17, 2013 11:46PM |
connector; from the center pin of the HB mosfet to the two ground pins on the HB connector; and from the ground pin on the mosfet to the ground input of the board (probably the ground side of the 12v connector). Find the appropriate traces using continuity check or resistance mode on your multimeter, and check after to ensure you didn't create a short between any of these components in the process. It would be prudent to check for shorts before starting so you don't waste effort trying to fix a short you think you just created but was already there before you applied this fix. To understand this fix, pretend that no traces exist between the high current pathways of the 12v input and 12v pins of the HB connector; the ground input and the ground pin on the mosfet, and the center pin of the mosfet and ground pins on the HB connector. Assume you must create these pathways, then do so!|
Anonymous User
Re: ATX power supply and Sanguinololu controller March 18, 2013 12:35AM |
Re: ATX power supply and Sanguinololu controller March 18, 2013 12:43AM |
Re: ATX power supply and Sanguinololu controller March 18, 2013 01:02AM |
Re: ATX power supply and Sanguinololu controller March 18, 2013 01:19AM |
Re: ATX power supply and Sanguinololu controller March 18, 2013 10:56AM |
Re: ATX power supply and Sanguinololu controller March 18, 2013 04:39PM |
Re: ATX power supply and Sanguinololu controller March 18, 2013 06:01PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: ATX power supply and Sanguinololu controller March 19, 2013 11:13AM |
Re: ATX power supply and Sanguinololu controller March 19, 2013 12:02PM |
Re: ATX power supply and Sanguinololu controller March 19, 2013 03:32PM |
