Machining parts for the extruder...anybody doing it?
December 01, 2008 08:38PM
Hello,
I am new here and have spent some time looking at the RepRap project. While looking at what parts are required, I was wondering how people procure the parts for the extruder as most people don't have a lathe. Is there somebody here that makes these parts?
Since I am very interested in the RepRap project, wouldn't mind having a RepRap, and have a machine shop, I am willing to make the extruder parts...if there is some interest. I already spec'd out most of the materials and figure I could make the parts kit (barrel, nozzle, bearings, feed screw, etc.) for some cash or some sort of trade. (i.e. Somebody sends me some RepRap parts I need and I send them the nozzle kit...at least until I can build my own RepRap.)
What does everyone think?
Regards,
Brian Reifsnyder
Re: Machining parts for the extruder...anybody doing it?
December 01, 2008 09:13PM
Personally, I redesigned the extruder so that it didn't need any machined parts. You need to repost your offer in the "For Sale" thread and possibly talk to Ian about making a trade. I think you are going to be able to make a deal.
December 01, 2008 10:26PM
Hello,
I just found your re-designed extruder and it looks like a good solution to the machining problem. However, not everybody has the tools and/or skills to braze, either. Personally, I am hung up on figuring out the electronics end of things; but, I'll muddle through it when the time comes.
I'll post my offer in the "For Sale" section, as you suggest. But, I figured that it would be a good idea to post in the general discussion as I don't have anything for sale yet and more people read general discussion forums. I want to gauge the interest in it first. If the reaction is positive, I'll make up about 8 or so kits and see what happens. (I figure 8 because I have to buy M6 threaded rod by the meter.) If the reaction is extremely positive, I'll tool up to make larger quantities faster.
Regards,
Brian
December 01, 2008 11:55PM
I think you're going to get a lot of interest. smileys with beer
sid
December 02, 2008 04:10AM
Hang on reifsnyderb,
if all goes well we have some readymade heaterbarrels early next year winking smiley
Than there's just the screw left to machine (that can be done with a drill and a file winking smiley)
Until then you may want to take a look at bitsfrombytes.co.uk
There's an extruder kit you can built without any machining.
'sid
December 02, 2008 10:20AM
Brian, et al,
I've been pondering doing something similar, though tweaked to use imperial-unit threads (easier, lower cost in the US.) My interest is more in fostering a local reprapping community (in greater Boston) than for profit. I'm still prototyping, but will post details when/if my design is both stable and working reasonably well.
Sid:
What readymade heater barrels are you referring to?
Would you please post more info, if you can?
-- Larry
December 02, 2008 12:13PM
Interested but where are you, reifsnyderb? Is this a UK only thing or in the US too? I keep busting my damn heater barrel and PTFE assembly and having another source for them would be very nice.
Demented
December 02, 2008 12:19PM
Larry,
I was thinking about using imperial units, as well. However, for the sake of compatibility, I am going to keep with metric. But, as you know, metric could be considered "odd" imperial measurements. grinning smiley
Also, there is no tolerance listed on the web page for these parts. So, for the 16mm diameter PTFE holder a piece of 5/8" PTFE should work fine as 16mm is 0.630 and we would only be under by 0.005. This would be slightly under a +-0.1 mm tolerance by roughly 0.001. If we were to assume a tolerance of +-0.1 mm (+-0.004), then machining all of the parts would be quite easy anyhow.
In order to avoid having to thread metric, I am planning on obtaining M6 threaded brass rod as it is $17.69 per meter. So, for each meter, I have the threaded materials for 7 kits. That puts the materials cost, for the threaded rod, at $2.53 per kit.
Regards,
Brian
December 02, 2008 12:20PM
Hello,
I am in Pennsylvania, USA.
Regards,
Brian
December 02, 2008 01:39PM
Brian,
I *think* the extruder tip at rrrf.org is an acorn nut with 3/8"-16 (UNC) thread; if so the other parts I now see there probably match that. I'm planning to stick with that for the hot parts of my extruder, so I could mix/match. Something may be amiss at the rrrf.org store site; I'm getting errors on some items, like the extruder tip.
-- Larry
December 02, 2008 05:10PM
Larry,
3/8-16 is what I remember too...
Demented
sid
December 02, 2008 07:01PM
Larry,
I had exactly the same trouble with machining parts, so I kindly asked a company (who's making soldering irons) to custom build one of there desoldering heaters to match...
And they did... almost that is, at the moment there's too little resistance for the heating element, and a type E thermocouple which should be a type K.
Nevertheless nopehead and Zach do have a prototype, oh well and me too winking smiley
Hopefully Chris and Zach can test that thing soon (I'll have to wait for the thermocouple Kit from Zach which I ordered today)
And if it's reliable, and possible to control, not leaking (winking smiley)
and so forth we will try to make the improvements necessary for a larger number of heaters, that'll take some time I guess, but if all goes well enough I guess two to three months (durability should also be tested winking smiley).
After that you'll surely find more informations on this topic.
And as a sneak preview... here's a photo of the prototype:
'sid
December 02, 2008 08:36PM
Sid,
Thanks much for the info and the sneak-preview photograph.
(When it can be revealed, please post the name of the company that prototyped this; the very least we can do is give them some publicity -- and business when our irons need replacment.)
-- Larry
December 02, 2008 08:55PM
Larry_Pfeffer Wrote:
> Brian,
> -- Larry
Larry,
I just checked and 3/8 - 16 is nowhere close to M6. M6 is closer to 1/4 - ?. I'd have to double-check; but, I think M6 is even smaller than a 1/4".
Regards,
Brian
December 02, 2008 08:58PM
sid Wrote:
> Larry,
(snip)
> 'sid
Does this mean I shouldn't bother?
Regards,
Brian
December 02, 2008 10:16PM
No, it doesn't mean that. It simply means that sid is trying to solve the problem in a different way, just like I have. smiling smiley
December 03, 2008 07:12AM
> a 1/4".
Brian,
Yes, that's true. However the acorn-nut extruder tips at rrrf.org are 3/8"-16.
I'm not sure exactly why, but my guess is that 3/8" is easier for reprappers (without access to a lathe) to drill out without breaching the sidewall. So, I think that's the right place (for me, at least) to start.
-- Larry
sid
December 03, 2008 08:01AM
No no.. please go ahead Brian!
It's just that I thought, it'd be a benefit for unexperienced users to just connect some cables and not machine screws, wind nicr wire, play around with firecement and such.
Making things as easy as possible will help spread the idea I think.
For those who know how to do things there will always be a homemade version of heaters, and you'll speed the process winking smiley
Larry, since it's a big company selling their products all over the world under different brands, I'd like to keep their mailboxes clean with questions about this, I'll let you know as soon as we have a massproduction winking smiley
'sid
December 03, 2008 08:10AM
I think that that is a good guess. As you saw on mine, I use 5/32" hard copper tube which has an ID of a touch over 3 mm to do the same thing. One thing that you have to keep in mind is that the extruder barrel on the Darwin extruder is threaded into the PTFE thermal break and, by and large, that connection has to resist the downward thrust of the filament being forced into the heated extruder barrel. At elevated temperatures PTFE gets a little soft, so you need the bigger diameter to provide enough thread contact area between brass and PTFE to resist that thrust.
December 03, 2008 08:48AM
> than a 1/4".
According to this table: [www.aaronspushnuts.com] the nearest equivalent to M6 is 1/4-28. Looks like about 5% larger in diameter and about 10% finer pitch.
December 03, 2008 08:54AM
Very interesting!
It looks like the heater fits into a external sleeve that has tip to send more heat out to the tip.
Where does the filament enter?
sid Wrote:
> Larry,
> a type K.
> this topic.
> prototype:
> [forums.reprap.org]
> body_attachment=1
> 'sid
