Re: 3D Metal Printer Projects? April 19, 2013 02:47AM |
Re: 3D Metal Printer Projects? April 24, 2013 05:23PM |
Re: 3D Metal Printer Projects? April 25, 2013 06:44AM |
Re: 3D Metal Printer Projects? April 25, 2013 08:39AM |
Re: 3D Metal Printer Projects? April 26, 2013 09:28AM |
Re: 3D Metal Printer Projects? April 26, 2013 11:38PM |
Re: 3D Metal Printer Projects? May 03, 2013 03:17AM |
As I sit here studying for my manufacturing final, I came across the process used for injection molding of powdered metals. A mixture containing 25 to 40 percent polymer or wax as a binder is injected into a mold then the green parts are placed in a furnace to melt out the binder and sinter the metal. The reason I bring this up is because a less powerful laser would be needed to melt the polymer in the machine described above. Alloying of two particles, one with a lower melting point can also be done, with the one particle attaching through surface tension to the other particle.
Shapeways does it, it's just not ideal. Laser sintering is more of a technical challenge, but the precision and quality is well worth it.|
Re: 3D Metal Printer Projects? June 03, 2013 02:04PM |
Re: 3D Metal Printer Projects? June 09, 2013 10:51PM |
Re: 3D Metal Printer Projects? June 19, 2013 05:46PM |
Re: 3D Metal Printer Projects? July 09, 2013 06:28PM |
Re: 3D Metal Printer Projects? July 09, 2013 06:31PM |
Re: 3D Metal Printer Projects? July 09, 2013 06:37PM |
Re: 3D Metal Printer Projects? July 09, 2013 09:27PM |
Re: 3D Metal Printer Projects? July 11, 2013 08:27AM |
kvarma
please email me with further questions, I can educate you on how advance 3D Metal printing has actually gotten!
Re: 3D Metal Printer Projects? October 22, 2013 08:04AM |
Re: 3D Metal Printer Projects? October 27, 2013 03:44PM |
Liquid Metal Jet Printing (LMJP) is a progressive form of 3D printing (also referred to as additive manufacturing). Using a head much like that of an ink jet on a paper printer, the machine lays down droplets in layers of molten aluminum that build up gradually. At the end of the process, an object of great complexity can be created with no labor and no energy on the part of the maker.
It has been awhile since the last update, and we have been hard at work on the project, just yesterday we did a full systems test, which is the first time we had all of the subsystems running together The test had some encouraging results as well as some disappointment, all of the subsystems worked as anticipated, which is a good result, we were able to fire our driving mechanism more times than before without failure, and the driver propelled metal out of the nozzle however the jet assembly failed due to a crack in the ceramic adhesive that was formed during drying which lead to the nozzle being misaligned this lead to the formation of a large pool of aluminum in front of the nozzle thus preventing us from being able to tell if we were producing droplets with the jet v9, the crack was exacerbated by the high thermal stresses incurred in the kiln plus the high jetting forces due to the driver, which lead to a full crack that sheared the assembly in two thus stopping further tests this week, we will be continuing on with low temperature gallium tests this week to try to get a better understanding of liquid metal behavior within our jet, plus we will also be trying to solve our adhesive problems before carrying the learned knowledge back over again to the high temperature aluminum tests in the coming weeks.
Re: 3D Metal Printer Projects? May 08, 2014 04:22AM |
Re: 3D Metal Printer Projects? June 25, 2020 10:07AM |
Re: 3D Metal Printer Projects? June 25, 2020 01:02PM |
Admin Registered: 18 years ago Posts: 14,162 |
Re: 3D Metal Printer Projects? June 25, 2020 01:09PM |
Re: 3D Metal Printer Projects? June 25, 2020 03:10PM |
Re: 3D Metal Printer Projects? June 25, 2020 03:23PM |
Re: 3D Metal Printer Projects? June 25, 2020 03:57PM |
