Re: Has anyone built a Prusa I3 ?
May 03, 2013 10:17PM
chris33 Wrote:
> it may have been fixed now but original they was
> 3.5
I looked at the drawing in Autocad a bit ago and the current .dxf shows a 3 mm diameter. My waterjet contractor reminded me that I told him I needed to tap 3 mm threads and he tightened the tolerance based on our conversation. I'll go back and make the holes in the .dxf 2.5mm. There were a few stray construction lines as well and we separated the plate and bed so his nesting software could be more efficient. I'll put the new drawings in my repo and submit the changes to Jo's repo.
May 04, 2013 04:32AM
Hi Chris33,
Please take into account the tolerance of your contractor's machine (maybe 0.2mm? then hole could go to 2.9mm) when deciding the hole size. We were advised against doing the holes this size laser cut, and they were just marked. But doing so, we also saved some money as the job became cheaper. Maybe a pilot hole around 2mm, if possible, may allow you to do the final drilling at home to the right size easily.
May 04, 2013 04:56AM
i had mine water jetted (before i found out the dxf i had the holes was 3.25mm as i stated) didn't want to risk getting burrs on the cut. the water jet tolarences are +/-0.2mm so my next frame the holes are going to do 2mm, but in all saying that mine is m4 and i dont have a problem i changed the rp parts to take m4
May 04, 2013 10:12PM
My waterjet guy says they can do between .003" and .005" tolerance on the holes which is about .07 mm to .1 mm. As missan says it's dependent on the machine and set up your contractor uses. If you didn't use an abrasive water jet I'm told you could get up to .025 mm tolerance though I didn't get a quote for something that exact.
May 05, 2013 05:49AM
Hi all,
I would like to build Prusa i3 printer, but I havent found any plans, dimensions and list of parts.
Do u know about it? Could U help me?
May 05, 2013 06:05AM
yes here's the link to the WIKI
May 05, 2013 10:01AM
thnx u chris33 smiling smiley
May 21, 2013 09:20PM
The original Prusa i3 BOM that lives at [ethercalc.org] has been edited into oblivion, but I made a copy and have been modifying it here: Thinkyhead's Curated Prusa i3 BOM.
| Lead Developer of Marlin Firmware
| Help support my work at Patreon and Elsewhere.
June 09, 2013 10:55PM
I had the chance to get a prusa I3 single Inox frame..but i do not know where to start from..
there's someone currently building a prusa I3 single frame, there's a manual --more material other than what's one the wiki?
cheers
open | download - prusa.jpg (119 KB)
June 10, 2013 01:50AM
You can use this manual: [github.com]
We are working on an interactive tool: [www.carlos-sanchez.com]
August 17, 2014 12:26PM
Hi all
I am busy part hunting for a Pursa i3 with a single aluminium frame. From all my reading it seems getting the wrong part files is quite an issue. Does any one have advice on which variant is best to build and where I can find the stl files therefor. I have access to a printer so will print my own RP parts. Even more of a problem for me is finding the file which I can use to cut the frame with a laser cutter. I have come across several but they are older versions or have been heavily modified. Any help would be appreciated as the excitement of building one is giving me sleepless nights.
