Re: Favorite Slicer? March 15, 2013 06:39PM |
Start of Gcode file produced by Kisslicer for the above part.
; *** Printer Settings ***
; printer_name = RED Tantillus
; bed_STL_filename =
; extension = gcode
; cost_per_hour = 0
; g_code_prefix = 4D31303920533C54454D503E0A4732205A0A4731205A312046363030300A473120583530205935302046363030300A473238205A302E300A4D3330320A0A3B205A2D6F6666736574206E656761746976650A4731205A302E310A0A3B205A2D6F666673657420706F7369746976650A473932205A302E30
; g_code_warm = 3B2053656C6563742065787472756465722C207761726D2C2070757267650A4D31303420533C54454D503E0A
; g_code_cool = 3B2047756172616E746565642073616D652065787472756465722C20636F6F6C696E6720646F776E0A4D31303420533C54454D503E0A
; g_code_N_layers = 3B204D617962652072652D686F6D652058202620593F
; g_code_postfix = 47312058302059302046363030300A4D3130342053300A4D3834
; post_process = NULL
; every_N_layers = 0
; num_extruders = 1
; firmware_type = 1
; add_comments = 1
; fan_pwm = 1
; add_m101_g10 = 0
; z_speed_mm_per_s = 150
; z_settle_mm = 0
; bed_size_x_mm = 100
; bed_size_y_mm = 100
; bed_size_z_mm = 215
; bed_offset_x_mm = 50
; bed_offset_y_mm = 50
; bed_offset_z_mm = 0
; bed_roughness_mm = 0
; travel_speed_mm_per_s = 120
; first_layer_speed_mm_per_s = 25
; xy_accel_mm_per_s_per_s = 3000
; lo_speed_perim_mm_per_s = 15
; lo_speed_solid_mm_per_s = 15
; lo_speed_sparse_mm_per_s = 20
; hi_speed_perim_mm_per_s = 75
; hi_speed_solid_mm_per_s = 50
; hi_speed_sparse_mm_per_s = 90
; ext_gain_1 = 1
; ext_material_1 = 0
; ext_axis_1 = 0
; ext_gain_2 = 1
; ext_material_2 = 0
; ext_axis_2 = 0
; ext_gain_3 = 1
; ext_material_3 = 0
; ext_axis_3 = 0
; model_ext = 0
; support_ext = 0
; support_body_ext = 0
; raft_ext = 0
; solid_loop_overlap_fraction = 0.5
; *** Material Settings for Extruder 1 ***
; material_name = PLA
; g_code_matl = 3B204D617962652073657420736F6D65206D6174657269616C2D737065636966696320472D636F64653F
; fan_Z_mm = 0
; fan_loops_percent = 100
; fan_inside_percent = 90
; fan_cool_percent = 85
; temperature_C = 185
; keep_warm_C = 130
; first_layer_C = 195
; bed_C = 0
; sec_per_C_per_C = 0.0015
; flow_min_mm3_per_s = 0.5
; flow_max_mm3_per_s = 10
; destring_suck = 4.5
; destring_prime = 4.5
; destring_min_mm = 1
; destring_trigger_mm = 5
; destring_speed_mm_per_s = 500
; Z_lift_mm = 0
; min_layer_time_s = 7
; wipe_mm = 10
; cost_per_cm3 = 0
; flowrate_tweak = 1
; fiber_dia_mm = 3
; color = 0
; *** Style Settings ***
; style_name = New 0.5 Default
; layer_thickness_mm = 0.15
; extrusion_width_mm = 0.52
; num_loops = 2
; skin_thickness_mm = 1
; infill_extrusion_width = 0.52
; infill_density_denominator = 3
; stacked_layers = 1
; use_destring = 1
; loops_insideout = 0
; infill_st_oct_rnd = 2
; inset_surface_xy_mm = 0
; *** Actual Slicing Settings As Used ***
; extrusion_width = 0.52
; num_ISOs = 2
; wall_thickness = 1
; infill_style = 4
; support_style = 0
; support_angle = 81.9
; stacked_infill_layers = 1
; raft_style = 0
; extra_raft_depth = 0
; oversample_res_mm = 0.125
; crowning_threshold_mm = 1
; inflate_raft_mm = 0
; inflate_support_mm = 0
; model_support_gap_mm = 0.5
; support_Z_max_mm = 154.5
; sheathe_Z_max_mm = 0
; Speed vs Quality = 0.50
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Favorite Slicer? March 16, 2013 03:51AM |
Re: Favorite Slicer? March 16, 2013 01:49PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Favorite Slicer? March 16, 2013 01:54PM |
Re: Favorite Slicer? March 16, 2013 02:13PM |
Re: Favorite Slicer? March 16, 2013 02:49PM |
Re: Favorite Slicer? March 16, 2013 03:11PM |
Re: Favorite Slicer? March 16, 2013 03:28PM |
Re: Favorite Slicer? March 16, 2013 03:45PM |
Re: Favorite Slicer? March 16, 2013 03:50PM |
Re: Favorite Slicer? March 16, 2013 04:02PM |
Re: Favorite Slicer? March 18, 2013 06:29AM |
Re: Favorite Slicer? March 18, 2013 10:15AM |
Re: Favorite Slicer? March 18, 2013 12:28PM |
You can ignore that, BFB printers still use it to calibrate, on the current released version it's used to set the maximum extrusion rate if you set it to one everything is in mm/s. One the current RC it's not used at all and the maximum extrusion speed is set per material in mm^3/sQuote
Kissslicer wants you to measure filament extruded per rev of the motor, I already have a perfectly calibrated e-step in my firmware - so this make no sense at all?
Kisslicer wants to be simple but if you've been using other slicers at all then things aren't simple at all, indeed a bit more cryptic. For instance the purge setting for 'suck' (known globally in everything else as retraction and extra filament) just seems wrong, why would you want to be able to set a value that can remove (or reverse) all the filament?
Cura is using Skeinforge as a backend, so I'd be interested in knowing what the setting difference is.Quote
Cura and Slic3r (not tested Kissslicer) do make smaller holes than Skienforge with ABS
Re: Favorite Slicer? March 18, 2013 01:12PM |
Re: Favorite Slicer? March 18, 2013 01:55PM |
Edge to edge is too small so corner to corner will be also but as the edges are straight they should be accurate. Outside dimensions are very accurate, which is also odd because with SF I have to scale up to compensate for shrinkage.Quote
NopHead, is the problem with the nut traps edge to edge or corner to corner?
Re: Favorite Slicer? March 18, 2013 02:09PM |
Re: Favorite Slicer? March 18, 2013 02:43PM |
Re: Favorite Slicer? March 20, 2013 10:54AM |
Re: Favorite Slicer? March 20, 2013 12:10PM |
Re: Favorite Slicer? March 20, 2013 12:38PM |
Re: Favorite Slicer? March 20, 2013 01:40PM |
Re: Favorite Slicer? March 20, 2013 05:38PM |
Re: Favorite Slicer? March 20, 2013 11:31PM |
Re: Favorite Slicer? March 21, 2013 11:00AM |
Re: Favorite Slicer? March 21, 2013 11:06AM |
Re: Favorite Slicer? March 21, 2013 12:07PM |
Re: Favorite Slicer? March 21, 2013 12:10PM |
Re: Favorite Slicer? March 21, 2013 04:20PM |
Re: Favorite Slicer? March 22, 2013 09:50AM |
