Hi all....
I seem to have a problem at the end of the print. i cant work out if it is at the last layer or the 1 before last.
The printer stalls or goes very very slowly around the same area and is still extruding!
See the result on the image!
i've attached the owl gcode
If that helps, i have a reprap pro using ABS, Pronterface and slicing with skeinforge.
is it a skeinforge setting issue?
