Where to get extruder plastic parts from? December 10, 2008 03:03AM |
Re: Where to get extruder plastic parts from? December 10, 2008 09:22AM |
Admin Registered: 19 years ago Posts: 1,915 |
Re: Where to get extruder plastic parts from? December 10, 2008 01:33PM |
Re: Where to get extruder plastic parts from? December 10, 2008 02:35PM |
Re: Where to get extruder plastic parts from? December 10, 2008 03:40PM |
Re: Where to get extruder plastic parts from? December 10, 2008 04:17PM |
Re: Where to get extruder plastic parts from? December 10, 2008 04:36PM |
Re: Where to get extruder plastic parts from? December 10, 2008 06:26PM |
Re: Where to get extruder plastic parts from? December 10, 2008 07:03PM |
Re: Where to get extruder plastic parts from? December 10, 2008 09:14PM |
Re: Where to get extruder plastic parts from? December 11, 2008 12:02AM |
Re: Where to get extruder plastic parts from? December 11, 2008 04:23AM |
Re: Where to get extruder plastic parts from? December 11, 2008 04:39AM |
, but on second though, how about $20? That would make it worth my while, and if I can keep my Reprap running 24/7, at that rate it would almost pay for the dingy basement corner of a printshop that I rent to run it in.
Note: at the moment, RepRaps do not run 24/7, no matter how hard you try. I've already given away two extruders pretty cheap, so I figure I can charge a bit more for these now. If that's too much, don't worry about it, I'll keep on doing what I've been doing.|
Re: Where to get extruder plastic parts from? December 11, 2008 04:47AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Where to get extruder plastic parts from? December 11, 2008 05:09AM |
FYI, my extruder has a 0.8mm thread pitch, and a 0.6 mm nozzle, but I generally stretch the filament to 0.5 mm to help span gaps and get a bit more resolution. I set the speed of the filament in RPM, using the M108S30.6 command (not the exact speed), which translates to 30.6 rpm on the drive screw, which you'd multiply by the thread pitch and the filament area to get plastic flow rate.|
Re: Where to get extruder plastic parts from? December 11, 2008 08:59AM |
Re: Where to get extruder plastic parts from? December 11, 2008 09:11AM |
Re: Where to get extruder plastic parts from? December 11, 2008 01:25PM |
Ah well, will try again with some edited Gcodes tonight.|
Re: Where to get extruder plastic parts from? December 11, 2008 01:45PM |
Re: Where to get extruder plastic parts from? December 11, 2008 02:16PM |
Re: Where to get extruder plastic parts from? December 12, 2008 12:38AM |
Re: Where to get extruder plastic parts from? December 12, 2008 11:53AM |
Re: Where to get extruder plastic parts from? December 14, 2008 05:15AM |
Admin Registered: 19 years ago Posts: 1,791 |
Re: Where to get extruder plastic parts from? / Alt. Extruder bearings. December 14, 2008 12:16PM |
Re: Where to get extruder plastic parts from? / Alt. Extruder bearings. December 14, 2008 02:40PM |
Re: Where to get extruder plastic parts from? / Alt. Extruder bearings. December 14, 2008 04:28PM |
Re: Where to get extruder plastic parts from? / Alt. Extruder bearings. December 14, 2008 06:06PM |
Re: Where to get extruder plastic parts from? / Alt. Extruder bearings. December 14, 2008 08:32PM |
Re: Where to get extruder plastic parts from? December 15, 2008 05:17AM |
Re: Where to get extruder plastic parts from? December 15, 2008 08:10AM |
