I made a part with various size cubes so that I could measure each after print to compare to the model. I want to get the printed part to be identical in size and dimensions as my model. The first print was a little over sized. the 40mm wide cube was 41.5mm wide. 30mm was 31.2mm. 20mm was 20.8mm. 10mm was 10.2mm. The height was the same as the model, 13mm.
So I did the math and adjusted best I could reducing the scaling to 96%
This fixed the size of the cubes but reduced everything in height. The total height now being 12mm.
Is there a way to only scale the X and Y axis?
