I was thinking the same thing at one point. But If i turn the temp down it doesn't extrude. Its from the same company that I got my printer, same hot end that came with it. Same thermistor.
Is it possible its the teflon tape on the threads? just a shot in the dark.
I did push the teflon wire coverings for the resistor farther down to protect it from shorting against the heat block, could these be burning?
Edited 1 time(s). Last edit at 03/29/2013 03:27AM by hendo420.
