Confirming my construction, did I do this right? March 30, 2013 02:29PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Confirming my construction, did I do this right? March 30, 2013 02:58PM |
Re: Confirming my construction, did I do this right? March 30, 2013 03:13PM |
Re: Confirming my construction, did I do this right? March 30, 2013 03:33PM |
Re: Confirming my construction, did I do this right? March 30, 2013 03:46PM |
Re: Confirming my construction, did I do this right? March 30, 2013 03:57PM |
Re: Confirming my construction, did I do this right? March 30, 2013 04:32PM |
Re: Confirming my construction, did I do this right? March 30, 2013 07:20PM |
Re: Confirming my construction, did I do this right? March 30, 2013 09:25PM |
Re: Confirming my construction, did I do this right? March 31, 2013 06:45AM |
Re: Confirming my construction, did I do this right? March 31, 2013 08:20AM |
Re: Confirming my construction, did I do this right? March 31, 2013 08:50AM |
Re: Confirming my construction, did I do this right? March 31, 2013 09:12AM |
Re: Confirming my construction, did I do this right? March 31, 2013 09:24AM |
Re: Confirming my construction, did I do this right? March 31, 2013 09:51AM |
Re: Confirming my construction, did I do this right? March 31, 2013 10:14AM |
Re: Confirming my construction, did I do this right? March 31, 2013 10:23AM |
Re: Confirming my construction, did I do this right? March 31, 2013 10:38AM |
Re: Confirming my construction, did I do this right? March 31, 2013 10:39AM |
Re: Confirming my construction, did I do this right? March 31, 2013 10:44AM |
Re: Confirming my construction, did I do this right? March 31, 2013 10:47AM |
Re: Confirming my construction, did I do this right? March 31, 2013 11:36AM |
Re: Confirming my construction, did I do this right? March 31, 2013 11:41AM |
Re: Confirming my construction, did I do this right? March 31, 2013 03:33PM |
Re: Confirming my construction, did I do this right? March 31, 2013 04:52PM |
Re: Confirming my construction, did I do this right? March 31, 2013 09:05PM |
Re: Confirming my construction, did I do this right? April 01, 2013 07:20AM |
Re: Confirming my construction, did I do this right? April 01, 2013 08:14AM |
Re: Confirming my construction, did I do this right? April 01, 2013 05:49PM |
Re: Confirming my construction, did I do this right? April 01, 2013 06:13PM |
Connecting... Sprinter 1.3.22T / 20.08.2012 start Printer is now online. SD Start SD init fail Soft PWM Init Planner Init Stepper Timer init Free Ram: 455 Plan Buffer Size:1152 / 16 >>>M303 SENDING:M303 PID Autotune start ok T:21.10 @:255 ok T:22.00 @:255 ok T:23.00 @:255 - ok T:148.00 @:254 ok T:148.00 @:254 ok T:149.00 @:254 - ok T:152.00 @:0 ok T:152.00 @:0 ok T:152.00 @:0 ok T:151.00 @:0 bias: 137 d: 117 min: 147.00 max: 152.10 ok T:149.50 @:254 ok T:148.00 @:254 - ok T:151.00 @:20 ok T:150.00 @:20 bias: 138 d: 116 min: 147.00 max: 153.00 ok T:148.70 @:254 ok T:148.00 @:254 ok T:148.00 @:254 ok T:148.00 @:254 - ok T:151.50 @:22 ok T:151.00 @:22 ok T:150.00 @:22 bias: 138 d: 116 min: 148.00 max: 152.00 Ku: 36.92 Tu: 72.76 Clasic PID CFG Kp: 5671 CFG Ki: 77 CFG Kd: 25790 Some overshoot CFG Kp: 2835 CFG Ki: 19 CFG Kd: 34387 ok T:149.00 @:254 ok T:148.00 @:254 ok T:148.00 @:254 - ok T:152.00 @:22 ok T:152.00 @:22 ok T:150.40 @:22 bias: 132 d: 122 min: 148.00 max: 152.30 Ku: 36.12 Tu: 72.76 Clasic PID CFG Kp: 5548 CFG Ki: 76 CFG Kd: 25232 Some overshoot CFG Kp: 2774 CFG Ki: 19 CFG Kd: 33642 ok T:149.00 @:254 ok T:148.00 @:254 ok T:148.00 @:254 - ok T:152.00 @:10 ok T:151.90 @:10 ok T:150.00 @:10 bias: 137 d: 117 min: 148.00 max: 152.00 Ku: 37.24 Tu: 65.68 Clasic PID CFG Kp: 5720 CFG Ki: 87 CFG Kd: 23483 Some overshoot CFG Kp: 2860 CFG Ki: 21 CFG Kd: 31311 PID Autotune finished ! Place the Kp, Ki and Kd constants in the configuration.h
//PID Controler Settings #define PID_INTEGRAL_DRIVE_MAX 80 // too big, and heater will lag after changing temperature, too small and it might not compensate enough for long-term errors #define PID_PGAIN 2560 //256 is 1.0 // value of X means that error of 1 degree is changing PWM duty by X, probably no need to go over 25 #define PID_IGAIN 64 //256 is 1.0 // value of X (e.g 0.25) means that each degree error over 1 sec (2 measurements) changes duty cycle by 2X (=0.5) units (verify?) #define PID_DGAIN 4096 //256 is 1.0 // value of X means that around reached setpoint, each degree change over one measurement (half second) adjusts PWM by X units to compensate
