Turning off bed and Extruder at end of print
April 03, 2013 03:08PM
Hi folks, I want to run my Mendel 90 overnight but want it to all shut down at the end of a print.
How do I set up in Pronterface to turn the bed and Extruder off when it finishes?
Thanks
Steve
Specialist prop makers. Pattern making,Fibreglass, foam carving, moulds, silicone rubber,
rotational moulding, resin casting, Robotics, product design and prototyping, Jesmonite
Teaching and Masterclasses
www.articolestudios.co.uk
www.articoleprops.co.uk
Re: Turning off bed and Extruder at end of print
April 03, 2013 03:30PM
Ive only been at this for a month but I think M1 could be put in your end G-code. M1 = sleep. It turns off all motors and heaters.
April 03, 2013 03:31PM
you would do it with gcode.
something like the following as your final code.
M104 S0 ; turn off temperature
M140 S0 ; turn off bed
M84 ; disable motors
if you use an atx supply you could also add M81 to turn of the power supply.
April 03, 2013 03:35PM
Bear with me .... How do I actualy do this.
If I load my file onto Pronterface using Kisl3r do I just type the code at the end?
Or what else do I do?
Steve
April 03, 2013 03:41PM
Kisslicer had a postfix section in the prt G-code tab. Any code you put there is added at the end of the generated g-code
April 03, 2013 04:00PM
Thanks folks
