Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] October 30, 2013 11:44AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 06, 2013 02:38PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 06, 2013 03:10PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 06, 2013 05:46PM |
dsnijders
Sanjay,
You need to fix your service side of the business!
It was easy to buy your hot end, but you are not responding to service claims.
I wasted my money on this hot end due to tolerance issues, it simply does not work.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 06, 2013 05:55PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 06, 2013 06:14PM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 07, 2013 06:26AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 07, 2013 12:46PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 07, 2013 01:26PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 07, 2013 03:21PM |
nophead
I would use a split in the block and a screw to draw it together making a clamp. That way it connects almost all the way round the cylinder.
Excalibur Hotend |
reprapzone.blogspot.de |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 07, 2013 07:21PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 07, 2013 11:20PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 08, 2013 07:33AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 08, 2013 09:43AM |
Jumperdome
Now my working plate would look different, but still be for a delta printer. So now my question to you would be first if you have some pictures which would show the mechanical connection.
And could you provide me the dimmensions of the actually sold metal hotend, so I could go forward and make the design my working plate? (Great would be a solidworks file)
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 10, 2013 06:46AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 11, 2013 01:52PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 11, 2013 11:52PM |
SanjayM
Milieri
I hope your issue is now resolved with the extrusion/filament grip/rubber thing. We use rubber as the extruder idler tensioner on our printers, and much prefer it to springs. Let me know if things work out for you, if not then I'll look into if it's a problem with our stuff - if it is, then we'll support you.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 12, 2013 02:08AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 13, 2013 02:19AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 13, 2013 03:42PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 13, 2013 03:58PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 13, 2013 04:17PM |
Admin Registered: 11 years ago Posts: 1,063 |
nophead
Why is rubber better than a spring? Seems like a spring will give a more constant force as changes in filament diameter are negligible compared to spring length but less so for rubber. Maybe that is not a significant disadvantage but where is the advantage?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 13, 2013 05:35PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 13, 2013 11:00PM |
I am running PLA at 260C Using the supplied thermistor adn temp_sensor_0 = 1 in configuration.h) so I'm sure you'll need to increase your hotend temperature as well for ABS. Do this, heat your hotend and insert filament in by hend (no extruder attached) to get a feel for the force required. Start upping your temparature until you feel you have no drips and the force required is reasonable. You may have to modify your configuration.h file (look for #define HEATER_0_MAXTEMP 275) if you exceed that amount.Quote
Justintime
I have been using my E3D for 2 weeks or so, and i am baId right now of pulling my hairs out.
I bought it to print better with ABS and no leaking elements.
It's not leaking.
But constant random jams.
ABS on 240 degrees and tried different colors all the same problem.
The hobbed bolt is eating like hell.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 14, 2013 12:57AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 14, 2013 07:34AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 14, 2013 09:49AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 14, 2013 10:02AM |
Justintime
@p40
You mean you feel friction when entering the heatbreak? Or at the beginning of the hotend?
It did came up to me to ream it up with a file. But then I read it was machinepolished inside. So didn't dare to.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 14, 2013 01:46PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] November 15, 2013 09:00AM |
