[Lots of pictures]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 12, 2014 01:44AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 12, 2014 02:58AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 12, 2014 07:28AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 12, 2014 02:34PM |
A2
Glass-transition temp:
Range: 45°C to 120°C, (113ºF to 248ºF).
Average: 59.6°C, (139ºF).
Wikipedia: 30°C, (221ºF).
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 12, 2014 02:44PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 12, 2014 02:49PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 13, 2014 01:10AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 13, 2014 02:04AM |
Admin Registered: 13 years ago Posts: 1,063 |
eagreen
me again,
after a full clean i thought it may be that the heat transfer from heating block to the nozzle maybe bad, because it screws in very loose until pressed against the heatbreak. so i added some thermal grease to the winding. after reinstalling it printed well for about 40 mins @210° and jammed again :/
i dont really see if the temporary fix was cleaning the hotend or the nozzle thing, but filament touching the nozzle from outside melts almost instantly so this couldnt be the problem anymore. will do some more testing today, maybe its heat creeping up the heatbreak, when it jams its not theres no nozzle clog but the force needed to push filament throu rises so high that my extruder starts rotating backwards after some steps (increasing motor current didnt solve it)
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 13, 2014 05:55AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 13, 2014 07:27AM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 13, 2014 08:13AM |
nophead
The problem is there is not a good thermal connection between the filament and the walls until it has softened and expanded, so heat can conduct up the filament. This is why I maintain there needs to be a mould relief taper in all metal hot ends and no seams in the cold part for the filament to jam on.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 13, 2014 09:48AM |
gmh39
I have found when I am using PLA I need to have my filament tension set lower than usual. Not sure if it is a freak kinda thing or what.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 13, 2014 04:35PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 13, 2014 11:37PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 14, 2014 12:16AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 14, 2014 01:01AM |
thejollygrimreaper
bruce356
Hi nophead,
nophead
Can you please explain / demonstrate what you mean by this, not sure where to put the taper or in which direction.
Thanks - bruce
here's one of nopheads posts on the topic, here
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 14, 2014 01:37AM |
CraigRK
thejollygrimreaper
bruce356
Hi nophead,
nophead
Thanks - bruce
Reading the whole of the Hydraraptor blog is a worthwhile exercise to understand a lot of the research etc that went into getting us to where we are today. The only thing I find frustrating is that there isn't an easy way to get see updates to the comments as there is a lot of valuable information in the comments as well.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 14, 2014 03:17AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 14, 2014 01:46PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 15, 2014 04:24AM |
thejollygrimreaper
CraigRK
thejollygrimreaper
bruce356
Hi nophead,
nophead
Thanks - bruce
i've spent many many hours reading that blog
Anonymous User
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 15, 2014 10:45AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 15, 2014 11:02AM |
It would help the community if you posted about your good experiences as well, not only the bad. This is human nature, to only complain when things go wrong, and not commend when things go well.Quote
3DogNate
this is my first post and first time I've been disappointed with a 3D printer part I've purchased.
Well, maybe you should take your time to read through other experiences. Then you will know that when there were issues, especially if caused by the hardware, that Sanjay has tended to resolve these things really quickly.Quote
3DogNate
I didn't even take my time and reading this thread for others experience... just thought I'd share my own experience with it. Not happy with it... and I'm pretty sure it's not worth my time to go through Filastruder and have them work with e3d in th UK to work it out.
Anonymous User
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 15, 2014 11:19AM |
CraigRK
I have no relationship to E3D, other than having bought a hotend from them (I do supply pellets for Filastruders, but again, I have no direct association with Filastruder). I haven't used it yet, so can' comment, good or bad, however, I have two issues with your post:
3DogNate
3DogNate
You would also know (if you have been following the Filastruder forums) that Tim Elmore treats his Filastruder customers exactly the same way.
So instead of simply blowing off in public, why don't you drop them an email (which you should have done at the first sign of trouble) and see what they do about. From everything I have observed on the forums they will not ignore you.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 15, 2014 01:46PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 16, 2014 12:51AM |
thejollygrimreaper
nophead
I've got some taper reams on the way for doing just that
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 16, 2014 02:50AM |
A2
thejollygrimreaper
nophead
@thejollygrimreaper:
Selecting a tapered reamer for the bore of the hot end barrel.
Of the commonly used filaments used for 3d printing, Nylon can have the greatest shrink rate.
The shrink rate for Nylon can range from .007” to .025” in/in.
If you were to machine a taper into the barrel of the hot end for a depth of 1.00”, what angle would you choose?
I'll make the assumption that shrink rate is equivalent to the expansion rate when Nylon is heated to its extrusion temperature.
Filament diameter 1.75mm = 0.069”.
Dia 0.069” * 0.025% shrink rate = ~0.002” total expansion of the filament diameter.
0.002/2 = 0.001” expansion per side.
Tan = .001”/1.00”= 1.745 degrees per side.
Or 3.49 degrees included.
What is incorrect with this logic is that I'm choosing the length over which the expansion is taking place, 1.00”.
A lower temperature reduces the rate of expansion.
The temperature is reduced as you move away from the nozzle, and up the barrel toward the cold end.
The length of the taper is dictated by the length of the temperature gradient, not by me arbitrary choosing a length of 1.00”.
Therefore for each unique style of hot end there will be a different taper inside the barrel due to the hot ends ability to shed its heat.
Knowing the drop off temperature along the barrel length, and the materials rate of expansion at different temperatures,
is fundamental to determining what tapered reamer to use, and for how deep it should be.
If you have an oven that can maintain a set temperature accurately, you can deduce the amount of expansion your self.
The other commonly used filament shrink rates are much less than Nylon, and would necessitate a shallower angle than what is required for Nylon.
So for a universal hot end I would be testing materials that have the higher rate of expansion.
Have I made any errors in my logic or math?
You might get away with trial and error, it would be a subjective conclusion, and there is nothing wrong with that.
Maybe that is all that is required, old fashioned "make and break engineering", which I'm an advocate of for some types of product development work.
Indicators that you have made an improvement could be: reduced extrusion force, higher flow rate, less clogging, less extrudate swell, any thing else?
What tapered reamers have you selected to test, for what length will you apply the taper, and how will you gauge your hot end performance?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 16, 2014 04:10AM |
thejollygrimreaper
what happens is that the "transition stage plug" (as i now like to call it) grows into the thermal break and the friction very quickly piles on from there
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 16, 2014 05:08AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 16, 2014 06:31AM |
nophead
Any forward pressure makes it spread outwards until it meets the walls.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 16, 2014 07:33AM |
