Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 16, 2014 08:54AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 16, 2014 03:44PM |
nophead
You have the taper in the blue section the wrong way round
nophead
and the one {taper} in the red section will have little effect because the plastic is a liquid at that point.
nophead
I still don't see how thermal expansion is relevant.
nophead
and is only about 0.5%, less than the tolerance of the filament.
nophead
If you consider the thermal break on the E3D is only about 2mm, that is less that the filament diameter so heat is bound to spread upwards in the middle of a short fat cylinder that is heated at the bottom but only cooled at the edges.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 16, 2014 06:41PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 16, 2014 08:26PM |
Admin Registered: 11 years ago Posts: 1,063 |
A2
I think both hot ends would benefit from an internal taper to make it easier to move the plug, i.e. the Tg zone.
They both look good, but what one has the shorter Tg plug?, and how would you verify it?
“idle hot ends are the devil's workshop”:
I think Ideally a steady state of constant extrusion is desired to achieve predictable thermal mapping, and to mitigate the length of the Tg of the plug.
Maybe all that is required is a script to constantly extrude while the machine is paused.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 17, 2014 02:00AM |
A2
@bobc:
One long taper looks good, and I'm sold on the idea of using one long taper. So what taper will be the ideal? I think it should be calculated based on the rate of expansion, as I stated in my earlier post.
nophead
Ideally you don't want heat input in the blue zone.
You only need enough support to guide, and prevent buckling of the filament in the blue zone. I think that a taper in the blue zone reduces the contact surface area.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 18, 2014 05:36AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 19, 2014 07:40PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 19, 2014 08:17PM |
biszkopt80
Any news when i will be able to buy your hotend Sanjay? On your shop from long time is pre-order,but i can get all parts separate.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 19, 2014 11:39PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 20, 2014 08:03AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 20, 2014 12:38PM |
SanjayM
On tapers
Tapers are something I really want to experiment with, getting tiny reamers for 2mm holes (1.75mm filament) is a pain though. I'm going to look into getting some made up custom to get exactly the right geometry inside the break perhaps. There's definitely some gain to be had if stiction can be reduced or eliminated. It may also allow for a longer heat break, with less conduction, and therefore a smaller heatsink.
Bryan Enander
Left hand spiral reamers should be selected for through holes. A through hole has an opening on the other end. If you put your eye up to the hole, you would be able to see out of the other side of a through hole. A left hand spiral pushes the chips ahead of the reamer and out the other side of the hole. This reduces the chances of scarring the work-piece and reduces the chance of damaging the reamer by previously cut chips. Additionally a left hand spiral helps bridge interruptions such as cross-holes or keyways. Left hand spirals are excellent for reaming hard materials and typically provide the best size and finish as compared to right hand spiral or straight flutes.
A left hand spiral fluted reamer that is right hand cut is better for cutting harder materials because the opposing forces of the left hand spiral and the right hand cut balance each other out resulting in rounder and straighter holes.
[blog.supertoolinc.com]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 07:24AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 07:47AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 08:39AM |
biszkopt80
This Stratasys ainc lookslike some patent troll,look how many patents they have, they shold ban companys like this to sell and buy in EU
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 08:47AM |
andin
I am thinking about using the famous E3D hotend in a new printer design that I am working on. The reviews are amazing - I am convinced that it is truly the best hot-end out there - good job! Nevertheless, in light of the recent patent infringement case in the US, I am worried whether the E3D design potentially infringes on the thin-tube liquifier patent:
Patent US6004124
I am aware that it is often impossible to give a definite answer, and most of us are no lawyers here. However, some indication/thoughts/opinions would help a lot. I am sure that there are many other printer developers asking themselves the same question.
@Sanjay: Particularly your thoughts on this would be very helpful!
Thanks
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 08:54AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 10:09AM |
andin
I did notice these claims. However, they represent narrow claims. In Patents, I believe that the general claims are more important,
... at least to my knowledge of reading patents. I.e. Claim (1) in this case would fit well into what the E3D design achieves with a thermal break between the hot-end and the cold-end (heatsink):
1. An extrusion head for depositing layers of solidifying material in a desired pattern to form three-dimensional physical objects, the extrusion head comprising:
a heating block made of heat conductive material;
a heating element to heat the heating block;
a first thin-wall tube having an inlet end for receiving a flament of a first material, an outlet end for delivering the first material in a molten state, and having a first section adjacent the inlet end and exterior to the heating block and a second section which passes through the heating block;
a material advancee mechanism positioned to advance the filament of first material into the inlet end of the first thin-wall tube; and
a nozzle at the outlet end of the first thin-wall tube for dispensing the first material in a molten state.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 10:15AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 10:24AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 10:30AM |
bobc
Basically, Stratasys have patented heated tubes. (The "thin-wall" qualifier is meaningless, all tubes have thin walls).
It is a totally bogus patent, and I expect it to be ruled invalid in the Afinia case.
Instead of working around bogus patents, we should be getting rid of this stupid patent system.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 11:58AM |
tjb1
bobc
"the first thin-wall tube has a wall thickness in the range of 0.008-0.015 inches, and an interior diameter of about 0.07 inches."
"the first section of the first tube is in the range of 0.02-0.04 inches long, and the second section of the first tube is about 2.5 inches long."
"the first and second metal tubes each have a wall thickness in the range of 0.008-0.015 inches, and an interior diameter of about 0.07 inches."
"the first section of the first and second thin-wall tubes are each in the range of 0.02-0.04 inches long, and the second section of the first and second thin-wall tubes are about 2.5 inches long.".
They already define thin wall as .008-.015, the E3D wall is .4mm or .0157" which is outside the definition. E3D is also located in the UK, not sure if Stratasys has any power there.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 12:03PM |
bobc
You are looking at the claims too narrowly, being outside the definition didn't stop them suing Afinia.
E3D is sold in the USA, so any sellers (or indeed users) in the US could be sued.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 01:05PM |
bobc
tjb1
bobc
Repeating stuff doesn't contribute anything useful, and it's still a bogus patent.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 08:02PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 08:29PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 21, 2014 08:58PM |
SanjayM
[snip...]
Recently I've been doing some statistical analysis of how problems occur and it has become clear that almost all issues surrounding jamming happen in 1.75mm versions, with most (80%+) of those problems being in 1.75mm Bowden systems. [snip...]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 22, 2014 01:07AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 22, 2014 08:13AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 22, 2014 08:22AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 22, 2014 10:01PM |
plexus
SanjayM
[snip...]
Just don't drop support for 3mm like so many other companies. 3mm is far superior to 1.75 and its not surprising to see your stats on this. I wish more people would request shops carry 3mm supplies because 3mm should be more prevalent when you consider its superior parameters for 3D FFF printing. I suppose if you are running direct drive multiple extruders you might be forced to go with 1.75 but in most other use cases 3mm is better. E3D's support of 3mm is why I decided on the hot end and its been working great!
