[Lots of pictures]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 09:31AM |
SanjayM
Patents
I'm completely unphased by the whole patent debacle here - we are lucky enough that we know some of the best patent solicitors here in the UK purely by personal connection. I did see the afinia case, particularly the "Thin wall tube" patent. They pretty much laughed at the patent as being incredibly narrow in it's scope - in particular regarding specific dimensions and materials. These dimensions and materials are not congruent with what we sell, and our product is quite different concept to the stratsys product described in patent.
The most key point here is that the "thin wall" is mandated in the stratasys patent as an area to increase conduction of heat in the melt zone. The thin walled tube is used in the heater block, so that heat can penetrate the thin walls effectively.
Trying to retroactively pin the use of a heatbreak with this patent is entirely erroneous when stratasys' patent applies to the "melt zone" in the design, not the "transition zone" that in an E3D nozzle has a thin wall.
TLR = Patent is crap, I'm not fussed.
crispy1
0.5mm is a pretty obvious and lacking nozzle size, I see no reason we shouldn't have these up for sale. We'll get those in stock - thanks for your input.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 10:21AM |
tjb1
plexus
SanjayM
[snip...]
Recently I've been doing some statistical analysis of how problems occur and it has become clear that almost all issues surrounding jamming happen in 1.75mm versions, with most (80%+) of those problems being in 1.75mm Bowden systems. [snip...]
Just don't drop support for 3mm like so many other companies. 3mm is far superior to 1.75 and its not surprising to see your stats on this. I wish more people would request shops carry 3mm supplies because 3mm should be more prevalent when you consider its superior parameters for 3D FFF printing. I suppose if you are running direct drive multiple extruders you might be forced to go with 1.75 but in most other use cases 3mm is better. E3D's support of 3mm is why I decided on the hot end and its been working great!
Far superior huh? In what way?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 11:43AM |
plexus
tjb1
plexus
SanjayM
[snip...]
3mm requires more torque than 1.75 which can be accomplished with a gear drive, either external as in a Wade or internal as part of the motor. The gearing allows the motor to generally run cooler. 3mm also requires less turns of the motor to get the same amount of material through. 1.75 allows easier use of a direct drive extruder however generally the motor will require a fan to cool it. that means more stuff to wire into the printer and more noise and a away to mount the fan. There are some benefits to a direct drive extruder but its much easier and less costly to run 3mm in a Wade type extruder. The only reason a direct drive is "better" is if the printer has a problem with using a Wade type and if that's the case, there might be something amiss with the design of the printer, unless its some kind of design that requires slightly less weight. A direct drive extruder can not run 3mm reliably unless gearing is implemented. A Wade type can run both diameters. So the better bet is a Wade type which can support both 1.75 and 3mm, allowing less motor stress and wear, no motor cooling fan. Running 3mm in a Wade type gives the least amount of stress to the motor and extruder than 1.75. 1.75 might "win" if we are talking about a multi-extruder set up. Generally 3mm has more benefits than 1.75 especially in single extruder set ups. Of course people have their own personal experiences, but in general this is the case.
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 12:15PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 03:12PM |
jkoljo
How do you explain there being less stress to the motor with 3mm filament? Also, 1.75 mm filament will usually give you better volumetric extrusion accuracy. The diameter accuracy in both is usually about the same, but the area is calculated with a second power of radius.. I agree with Sanjay that keeping both models is good, because of the flexible filaments.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 03:28PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 03:31PM |
gmh39
That makes me reconsider selling the huge box of 3mm abs I have...
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 04:28PM |
plexus
Hi Jkoljo. think of filament as being steel cable: its harder to pull thick steel cable off a spool than thinner steel cable because the thicker stuff is less flexible. so the motor needs more torque to pull the thicker material off the reel. this is why we have to use a geared extruder to get more torque from the motor, in exchange for speed. 1.75 is easier to pull off so you can use a direct drive extruder however you have to cool the motor because now the motor is going to spinning faster. this requires more power from the electronics and the motor will heat and require active cooling. there are some benefits to a direct drive extruder but from my perspective they are mostly aesthetic and not really benefits.
As for the claim of more accurate volumetric extrusion, this was initially a claim but I have yet to see proof that this matters. I have tried tests with both and see no difference. and with the E3D extruder which has a very narrow filament path down to the nozzle aperture, there will be no benefit to 1.75 over 3mm. if we required accuracy at very tiny amount of extrusion, perhaps, but with the kind of extrusion we typically use in FFF, there is no benefit.
There is no benefit of 1.75 over 3mm but there are benefits of 3mm over 1.75. unfortunately those that sell these things are tending to focus on 1.75 and some even only sell 1.75. its very unfortunate. it reminds me of the VHS vs Beta video tape format where where VHS won just because the industry pushed it harder than Beta, even though Beta had way better picture quality.
I am trying to get people to stop buying into this 1.75 kool-aid. i have had to set up my extruder to make for easy hot end changes and got myself a 1.75 and 3mm E3D hot end. i use the 1.75 only when I have to for materials I cant get in 3mm.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 04:34PM |
greenman100
plexus
You're wrong on so many fronts I don't know where to start. I guess I'll work chronologically through your post.
First of all, the extruder isn't working to pull the filament off the spool. The work being performed is forcing the melted polymer through the nozzle. 3mm requires about 3x the force of 1.75mm, as it has about 3x more area and pressure is constant for a given flow rate and nozzle size. Of course I am neglecting viscous drag, but that is worse for 3mm also as it has more surface area in the melt zone.
You're also wrong about there being no benefits to 1.75. A direct drive extruder is lighter and cheaper, no printed gears to fool with, fewer printed parts. It is also more compact. 1.75mm filament is also more flexible, more easily routed through compact spaces and enclosures.
I'm not saying one is better than the other, but to say there are no advantages to 1.75mm is to be blind.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 05:05PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 05:18PM |
jkoljo
whereas with especially bowden fed systems the 1.75 mm stuff is a clear winner.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 05:20PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 05:21PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 06:16PM |
jkoljo
(snip)
And as I mentioned, smaller filament is more forgiving when it comes to diameter accuracy, making volumetric extrusion more accurate. So how did you calculate your 50% number?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 06:22PM |
royfranz
[nip...] At the end of the day,
my decision may not be made on technical merit, but on availability of filament.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 07:35PM |
Admin Registered: 13 years ago Posts: 1,063 |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 07:47PM |
thejollygrimreaper
like it or not 1.75mm will become the standard size, 3mm eventually won't be available (a lot of suppliers in australia have stopped carrying it)
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 08:38PM |
Sublime
thejollygrimreaper
Not true. The reason we started using 3mm is because the big companies used it. The reason 1.75 came to market is because Chinese made Up printers used it because of either it being more proprietary and they were the only supplier for their machines and/or because it made their extruder cheaper with no gears. Either way it was about profit. Further more when I looked into having filament made most places that made welding rod could only go down to 3mm without retooling.
So in the end we will have the big expensive machines running 3mm and suppliers with experience and capabilities to make 3mm. Then we have home made filament where it seems easier to make 3mm. Lastly is if the manufacturer sell 3mm for the same price as 1.75 then 3mm has a higher profit because it takes less time to extrude.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 09:17PM |
thejollygrimreaper
Sublime
thejollygrimreaper
then why is 3mm not as available of not more than 1.75mm, and at a noticeably lower price?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 10:01PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 23, 2014 10:24PM |
gmh39
Solution:
Buy a filament extruder.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 25, 2014 01:17PM |
plexus
tjb1
plexus
SanjayM
[snip...]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 25, 2014 01:27PM |
plexus
You just have to face it. 3mm has more benefits than 1.75. Yes its thinner and cuter lol but its over-all inferior to 3mm.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 25, 2014 01:36PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 25, 2014 01:53PM |
Anonymous User
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 25, 2014 02:01PM |
SanjayM
If you are having issues with your hotend please please get in touch via the contact page on our site and we will do all we can to support you. We reply to every email, it might take us a day or two, but we stand behind our product. Your hotend absolutely should print PLA without issues, and if it isn't something is wrong, we'll work with you to sort it out. We have thousands of these things in the wild, and our failure rate is really low - less than 0.2% at last count. Problems happen, sometimes it's a problem with a particular machine or setup, occasionally it's a problem due to manufacture on our end. Whatever happens, if you paid for a hotend you should get something that works.
Cheers,
Sanjay
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 25, 2014 04:26PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 27, 2014 03:40AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 27, 2014 07:44AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] February 28, 2014 09:06PM |
