[Lots of pictures]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 01:03AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 01:55AM |
bruce356
Hi again, just printed with ABS and instead of jamming after 1.5 hrs with PLA it jammed after 2 hrs with ABS. Sorry but do not have much confidence in this hot end unless I got a bad one?
Regards - bruce
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 02:03AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 02:08AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 02:19AM |
bruce356
Regards - bruce
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 02:46AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 04:19AM |
bruce356
I have just pulled the hot end apart and found the inside bore in the stainless steel part has a spiral groove all the way through (looks like a course thread but not as deep as a thread more like a deeper scratch mark), do they all have this, it seems to me that this could cause the filament to jam when it expands in its rubbery state before liquefying.
E3D
CNC Machined Parts
High precision
High quality surface finish
All heated parts are either steel, aluminium or brass. By using a stainless steel heat-break and active cooling we have reduced the distance in which the plastic transitions from ambient temperatures to extrusion temperatures to 2mm. This extremely short transition from cold filament to molten plastic provides highly precise extrusion with little extrusion force and reduced jamming.
[e3d-online.com]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 04:57AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 06:08AM |
bruce356
Thanks, I understand your comments about machining I am a fitter and turner by trade,
bruce356
the internal finish in my opinion should be smooth after using a reamer,
when I run a small shaft (with a smooth tip no scratching) up and down inside the bore I can feel the bumps.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 09:22AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 01:09PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 01:44PM |
bruce356
Hi vegasloki, it is my first hot end, I thought all metal would be the best way to go. As posted above:-
"I have just pulled the hot end apart and found the inside bore in the stainless steel part has a spiral groove all the way through (looks like a course thread but not as deep as a thread more like a deeper scratch mark), do they all have this, it seems to me that this could cause the filament to jam when it expands in its rubbery state before liquefying."
You may be right about temperature as some run at 200+ degrees, my maxtruder came with a ball bearing idler I assume that should be ok. I am not impressed with the one sided only support of the spring-ball bearing assembly, its a bit crappy. Spring tension is at minimum and it bites into the pla and abs quite nicely giving good grip (as can be seen in photo). A JHead will be my next item to purchase.
regards - bruce
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 03:29PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 03:44PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 05:03PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 05:26PM |
bruce356
bruce356
In the model drawing above it does not show a chamfer or bevel at the hot end (left side) but mine has one.
bruce356
generally the finish inside the 2mm bore is very good, just the score marks spoil this finish.
I think I would be pushing it to try and lap these score marks out of existence without spending a lot of time and ending up with an oversize bore.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 07:50PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 01, 2014 11:35PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 02, 2014 12:24AM |
bruce356
If an extruder approaches a certain pre determined load the printer would stop, send an audible
alarm that something is wrong, the blockage in the extruder can be rectified and printing can continue
without ending up with stripped filament & failed print plus having to throw away the part or parts.
bruce356
Airtripper's extruder is a well designed extruder but I am not using Bowden.
, (PITA).
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 02, 2014 08:40AM |
bruce356
I know that E3D have been shipping the new smaller Semitec since November 2013, I bought mine from MakersToolWorks and they obviously still have old stock as I received my kit with the EPCOS 100k thermistor (2.5mm bore in heater block) so default table 1 would be ok.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 02, 2014 10:39AM |
crispy1
I would guess that you did not properly seat the nozzle against the heat break inside the heat block. There must be a gap between the flat on the nozzle and the bottom face of the heat block. See step 2 of this pdf: [files.e3d-online.com]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 02, 2014 10:52AM |
When I brought it back up to 300C to torque it down again, I also noticed that the cartridge heater was floating loose! (I let it cool down without adjusting, and the set screw held it again at room temperature.) The set screw holding it in was originally torqued cold, and I think that E3D might want to change the instructions to torque that hot as well. I don't think that a lot of torque should be applied hot, since it might damage the cartridge heater when everything contracts when cold.....
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 02, 2014 05:44PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 02, 2014 06:09PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 02, 2014 06:19PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 02, 2014 06:46PM |
bruce356
Hi all, by the way how do you guys insulate the E3D against the negative effects of air from the bed cooling fans (I have one fan on each side of the extruder/hotend). At 100% fan speed I have a little difficulty maintaining a steady temperature it tends to fluctuate by up to 5 degrees C.
At this stage I have just reduced fan speed to 35%, that solves the hot end fluctuations but does not provide enough cooling for PLA.
Thanks and regards - bruce
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 05, 2014 06:33AM |
Anonymous User
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 06, 2014 11:19AM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 06, 2014 11:38AM |
Anonymous User
Re: Update on the E3D All Metal Hotend (Now finally shipping!) [Lots of pictures] March 06, 2014 12:04PM |
