What's a good source of Nema17 Stepper Motor for 3D printer
April 15, 2013 09:00AM
Reprap Wiki has recommended lots of NEMA17 stepper motors for 3D Printers.
Besides price consideration, what do you need for your 3d printer building, a Nema17 stepper motor?
1. 5mm motor shaft is most popular and you could find pulley for it easily. A flat shaft 5mm is good choice for the extruder.
2. 4 lead wires as long as possible. 700mm lead wires w/ both connectors for Motor and Electronic Boards are recommend.
3. The motor supplier can supply you with T2.5 16 gears Pulley or GT2 20 teeth Pulley in the same time. T2.5 or GT2 belt available.
4. Threaded rod NEMA17 stepper motor are supplied for your Z axis.
Any more you want? We do the best.
Edited 1 time(s). Last edit at 04/15/2013 09:02AM by robotdigg.
SKYPE: robotdigg
www.robotdigg.com
Re: What's a good source of Nema17 Stepper Motor for 3D printer
April 15, 2013 09:59PM
They need to be rated at 1.5 amps or less to work with most drivers available for the 3d printers. (I know that most drivers are rated for 2 amps, but you need a fan on them to work at 2 amps)
April 16, 2013 05:32AM
Nothing wrong with supplying a 3 amps stepper with only 1 amp. You get tourque for 1 amp only, of course, so a 3 amps motor is often heavier than neccessary.
Usable stepper motors are bipolar (4, 6, 8 wires), have at least 200 steps per turn and are rated for 6V or less.
April 16, 2013 06:07PM
Uhm.
5. Rated current of the motor 0.8-1.5A per phase.
April 25, 2013 01:17AM
New online RobotDigg
