Source for mm smooth rods in USA?
Posted by Thanos_of_MW
April 22, 2013 01:09PM
As the title says grinning smiley
I've been lurking here for a while and have decided to start my build. So far I have only found metal sources in inches. Any idea where to get 8 mm smooth rods in the USA? I rather find something locally to avoid expensive shipping costs, VAT (from Europe), etc. Working on a very tight budget here (personal use). My concern is with the fit of linear bearings on imperial sized rods. Any guidance will be appreciated.
Re: Source for mm smooth rods in USA?
April 22, 2013 01:14PM
mcmaster.com
Edited 1 time(s). Last edit at 04/22/2013 02:46PM by akhlut.
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
April 22, 2013 01:30PM
VXB.com will sell you chrome plated hardened steel rods in various lengths, buy it the size you want it's a pig to cut.
But use McMaster.com if you just want drillrod
___________________________________________________________________________
My blog [3dprinterhell.blogspot.com]
April 22, 2013 03:37PM
Drill rod is hardened and is also drawn to a precision tolerance. The composition of the alloy is a more important factor than any sort of plating. Typically hardened tool steel is a high carbon alloy with chromium and molybdenum as well as manganese and other elements. The elements give the material tensile strength and allow the various hardening processes to work. Plating processes don't have the tolerance of a quality drawn steel rod. A shinny finish for drill rod is achieved by a light buffing just enough to put a shine on it and clean any dirt, paint, etc that might make it onto the rod in the manufacturing process. The paint comes from marking the rod ends for identification of the hardening process. As it's hardened it's a bit tougher to cut. I use what is called a metal cutting dry saw and finish the ends with a bench sander. You can cut them by hand but it could take a few hacksaw blades and something to firmly hold the material like a vise. The printers I use/ built as well as the couple hundred kits I've supplied work well with drill rod.
April 22, 2013 05:46PM
The only issue I have with drill rod, is if it isn't hardened, the bearings in the LM8UU's will wear them. But were talking about 100's of hours of printing and then you can just rotate them slightly.
I find drill rod relatively easy to cut and machine, my bandsaw cuts through it in a few seconds, I am using drillrod in my current design, but I'm using bronze bushings on them not LM8UU's.
the VXB rods I have are hardened, the only thing I can cut them with is an abrasive cutoff wheel
April 22, 2013 09:01PM
Drill rod is not hardened.
April 22, 2013 11:09PM
Wow. Lots of very informative answers. Thanks guys for the valuable information.!thumbs up
April 22, 2013 11:19PM
Go here:
[www.mcmaster.com]
Note that none of these are very hard. They can be hardened - but may want to skip it to save the money.
Make sure to only get the precision ground.
open | download - Screen Shot 2013-04-22 at 11.14.35 PM.png (250.8 KB)
April 23, 2013 10:37AM
Misumi is what all the automation guy use,
[us.misumi-ec.com]
Example - 8mm shaft @ 400mm length - $9.70
Customize any diameter/length. You can pick surface finish, and a whole slew of options
Edited 1 time(s). Last edit at 04/23/2013 10:40AM by ShadowRam.
April 23, 2013 12:29PM
> [us.misumi-ec.com]
> 20000000_20010000.html
Cool! Checking it out now. I'm basing my printer on the Mendel 90 design, but inside a heated chamber. Since I have the chamber (donation from my place of work), I need to "resize" the rods from the original dimensions so I can use the whole volume of the box.
April 23, 2013 01:53PM
If you're building the entire printer inside a heated chamber there are additional issues ,like how the plastic and more importantly the steppers hold up at the elevated temperature.
Ideally you want the steppers outside the heated part.
April 23, 2013 02:06PM
> slightly.
> LM8UU's.
Wouldn't another advantage of the hardened, chromed rods be stiffness? I can't help but notice on my MendelMax that the rods do flex. In fact, I think the stifness of the filament can and does influence the precision of the print due to the torque it imposes on the X-rods. I can move the filament around with my hand and see the print head move. I can also see movement in the bed from the Y-rod flex as well with just fingertip pressure. I'm using 8mm drill rod now but seriously considering switching to larger (10mm),hardened rods.
ΜΟΛΩΝ ΛΑΒΕ
April 23, 2013 02:37PM
Hardness does not affect stiffness. Going from 8mm to 10mm rod will decrease the flexibility of the rod significantly though.
April 23, 2013 03:03PM
Thanks. Did a little reading on material science.. "Stiffness" is the material's ability to resist elastic deformation, while "hardness" is the material's ability to resist plastic deformation. Hardening steel does not make the steel more stiff, however it does increase the yield point and the range of the elastic region.
For the rods in the printers, this isn't much help.
ΜΟΛΩΝ ΛΑΒΕ
April 23, 2013 07:09PM
That's not correct. Drill rod is indeed hardened by using a hardening processe. The processes can include air hardening, oil hardening and water hardening. Dril rod is extruded to a precision tolerance using a tool steel alloy which is harder than mild steel. Depending on the app and desired hardening determines which method is employed. Water hardening drill rod (the most basic) is just fine for Reprap builds though in the US it's a bit more difficult to find in metric sizes but it's out there. I've found oil hardening (O-2, which is what I use) to be more available. I use a few hundred pounds of rod a month for printer kits. FWIW my background encompasses more than three decades in an engineering field with experience in material science.
April 23, 2013 07:11PM
> isn't hardened,
Drill rod is hardened. Non hardened rod is called round stock. Some mistakenly call unhardened, non alloy tool steel drill rod when it's really round stock.
April 23, 2013 07:18PM
> material science.
Drill rod is an alloy that is hardenable by various methods (depending on which one you buy), but it is not hardened when you buy it - it is called drill rod because you can machine it into drill bits and then harden it. Take for example the General Purpose Water-Hardened W1 Tool Steel from McMaster:
[www.mcmaster.com]
It is listed as 241 Brinell. That is about 23 HRC. After you water-harden it, it becomes up to 60 HRC.
Round stock differs in that it is less precise, and also made from a lesser alloy steel. But neither come to you already hardened when you buy them.
I made these bullets out of drill rod, and hardened them myself:
[www.youtube.com]
Edited 3 time(s). Last edit at 04/23/2013 07:27PM by rsilvers.
April 23, 2013 07:52PM
I buy a few hundred pounds of hardened drill rod a month, it's readily available. To say drill rod isn't delivered hardened is not accurate. Many sell raw material that requires hardening but many others also sell material that is hardened.
Edited 1 time(s). Last edit at 04/23/2013 08:01PM by vegasloki.
April 23, 2013 10:22PM
> part.
Mmm... that would be a pain since the case is 1/8" steel plate with the exception of the rear and the front door (plexiglass). If I go with bigger motors (NEMA 23) with more torque than necessary, would the temperature still be an issue with them? Would Peltier coolers help? (radiated heat from the Peltier helping heat the chamber?) I read in some thread here that the temperature only needs to be around 35 Celsius in the chamber to print large ABS objects. I intend to print mostly in ABS and vinyl. The printer will also have a heated bed. I guess I'm going off-topic now tongue sticking out smiley
In any case, everyone is giving me great information and raising good questions. Thanks for the superb feedback.
April 23, 2013 10:23PM
You said: "The processes can include air hardening, oil hardening and water hardening" and "Water hardening drill rod (the most basic) is just fine for Reprap builds."
They may be just fine for certain projects, but they are not hardened. Only material specifically marketed as pre-hardened is hardened, and it is only air-hardened - not oil or water.
[www.matter-replicator.com]
