Disable End Stops on Repetier-host? April 29, 2013 03:34PM |
Re: Disable End Stops on Repetier-host? April 29, 2013 04:15PM |
Re: Disable End Stops on Repetier-host? April 29, 2013 04:32PM |
Re: Disable End Stops on Repetier-host? April 29, 2013 05:05PM |
Re: Disable End Stops on Repetier-host? April 29, 2013 05:46PM |
Re: Disable End Stops on Repetier-host? April 29, 2013 08:03PM |
Re: Disable End Stops on Repetier-host? April 29, 2013 09:56PM |
Re: Disable End Stops on Repetier-host? April 30, 2013 03:52AM |
Re: Disable End Stops on Repetier-host? April 30, 2013 04:52AM |
Re: Disable End Stops on Repetier-host? April 30, 2013 06:07AM |
Re: Disable End Stops on Repetier-host? April 30, 2013 07:14AM |
Re: Disable End Stops on Repetier-host? April 30, 2013 03:25PM |
Re: Disable End Stops on Repetier-host? April 30, 2013 03:47PM |
Re: Disable End Stops on Repetier-host? April 30, 2013 04:51PM |
Re: Disable End Stops on Repetier-host? April 30, 2013 05:50PM |
Re: Disable End Stops on Repetier-host? April 30, 2013 10:50PM |
Re: Disable End Stops on Repetier-host? May 01, 2013 02:34AM |
Re: Disable End Stops on Repetier-host? May 01, 2013 04:45AM |
Re: Disable End Stops on Repetier-host? May 01, 2013 05:14AM |
Re: Disable End Stops on Repetier-host? May 02, 2013 04:48AM |
com),home_all_axis || GCODE_HAS_Y(com),home_all_axis || GCODE_HAS_Z(com));|
Re: Disable End Stops on Repetier-host? May 02, 2013 05:04AM |
Re: Disable End Stops on Repetier-host? May 02, 2013 11:26AM |
// Test Z-Axis every step if necessary, otherwise it could easyly ruin your printer!
#if Z_MIN_PIN>-1 && MIN_HARDWARE_ENDSTOP_Z
if((cur->dir & 68)==64) if(READ(Z_MIN_PIN) != ENDSTOP_Z_MIN_INVERTING) {cur->dir&=~64;}
#endif
#if Z_MAX_PIN>-1 && MAX_HARDWARE_ENDSTOP_Z
if((cur->dir & 68)==68) if(READ(Z_MAX_PIN)!= ENDSTOP_Z_MAX_INVERTING) {cur->dir&=~64;}
#endif
// } moved to end
#endif
#endif
