Budaschnozzle repetier question
Posted by mgarsteck78
May 01, 2013 04:43AM
I bought the Budaschnozzle 1.2 to go on my pursa mendel reprap. Everything was working fine on my last hot end until I messed it up. I installed this new one and while the nozzle warms up, the temperature never shuts off. It is registering between 40-50°C. It is obviously hotter than that. Im not sure what the problem is.
Im using Repetier-Host along with the firmware.
Any ideas?
Edited 2 time(s). Last edit at 05/01/2013 04:43AM by mgarsteck78.
open | download - Screen Shot 2013-04-30 at 8.35.51 PM.png (145.5 KB)
Re: Budaschnozzle repetier question
May 01, 2013 05:31AM
My guess would be a firmware OR repetier temperature setting that is off.
Did you check if you use the same thermistor in the new hotend? I doubt it, you should change that in your firmware settings.
May 01, 2013 09:46AM
seems like thermistor was not touching heated block. if so this is a main reason for failure. you can not monitor temp from ambient air.
May 01, 2013 12:16PM
Where would I look in the firmware? I cant find a heat table for this hot end
May 01, 2013 04:42PM
You need to set the thermistor type used inside the hot end, not the hot end type. See or ask theextruder vendor which thermistor he uses.
May 01, 2013 05:51PM
'Where would I look in the firmware? I cant find a heat table for this hot end'
look at the top of the configuration.h section of the page. there will be comments to select a number for what type of thermister is used.
May 01, 2013 07:46PM
Its not the thermistor, but I think it is the firmware. Im not sure what the hell is going on.
I made this change:
#define EXT0_TEMPSENSOR_TYPE 7
and
#define GENERIC_THERM1_BETA 3974
Anything else I should do?
Im getting this readout for temp.
May 01, 2013 09:39PM
this seems odd, what thermister type came with your Budaschnozzle 1.2? from auctions on ebay i think it is a EPCOS 100k
is there a chance that one side of thermister is contacting the metal of the heatsink along with a resistor lead?
Edited 2 time(s). Last edit at 05/01/2013 10:05PM by jamesdanielv.
May 02, 2013 02:03AM
Im assuming its the Honeywell 100k
May 02, 2013 02:43AM
Im getting
Printer set into dry run mode until restart!
and
extruder 0: temp sensor defect
May 02, 2013 02:47AM
You get that when your temperature is outside the defined normal range. You get this
- if you have no thermistor connected to the defined pin
- you have a short in thermistor
- your thermistor type is wrong, also it is hard to get into that range with the wrong 100k thermistor.
May 02, 2013 03:12AM
Ok then, so its a mechanical issue most likely?
May 02, 2013 03:32AM
No, i just saw you did
and
which is completely wrong. 7 is user defined table 3 not generic table 1 for which you would also need to do a
#define USE_GENERIC_THERMISTORTABLE_1
to activate it anyway. So basically your set table is nonse because you didn't define it.
If it is the epcos type set sensor type to 1
May 02, 2013 04:02AM
Ok, I reverted everything back to how it was before. Set the table to 1 etc...
This is what Im getting.
Edited 1 time(s). Last edit at 05/02/2013 04:02AM by mgarsteck78.
open | download - Screen Shot 2013-05-02 at 12.59.31 AM.png (294 KB)
May 02, 2013 04:09AM
So you are back at the beginning.
Have you checked what it shows at 25° room temperature. All 100K thermistors normally used have 100K at that temperature. So regardless of the changes at higher tems you should see 25°c for it.
You could also measure the resistance yourself. Have you checked that the budaschnozzle uses a thermistor and nor a thermo couple?
May 02, 2013 04:45AM
It stays at the constant temperature no matter what the temperature in the room or if the hot-end is turned on or not.
The nozzle uses a thermistor and I did check the resistance with a multimeter. The resistance changed with temperature change, so Im assuming that the thermistor is working fine.
May 02, 2013 05:08AM
So the thermistor seems to work and the firmware does not see it.
Sounds like you didn't connect the thermistor where you told the firmware. You could test this. If you disconnect while running and connected you should see the dry run message appear. If not the thermistor is not at the defined pin number or something is wrong with that input. You could try the Extruder 2 input instead.
May 02, 2013 05:28AM
Ok, I'll check that in the morning. Thanks a tonsmiling smiley
May 02, 2013 07:09PM
I tried the test that you suggested. Nothing happened as far as temperature reading change or switching to dry-run mode when I unhooked the thermistor wire. I killed the job and disconnected my printer. I came back and the hot-end was still turned on, despite all of that.
May 02, 2013 07:23PM
Reading all this, makes me doubt if the cables are connected to the right corresponding pins on your controller.
Are you absolutely sure everything is in the right spot?
May 04, 2013 04:33PM
I dont think they are hooked up incorrectly.
Edited 1 time(s). Last edit at 05/04/2013 05:02PM by mgarsteck78.
May 04, 2013 05:24PM
How is the temp reading of your bed? Have you tried changing the two inputs and see if the readings are then correct? That way you could see if it is a problem with the ramps board.
May 04, 2013 06:02PM
It still stays in that range of 50°C. Ill try swapping the pins.
May 04, 2013 06:21PM
swapped out the pins, nothing changed.
May 04, 2013 09:09PM
Oh, btw always turn off everything before swapping things!
I vaguely remember having the same issue before until I fixed my thermistor table. I got this information from studying the data sheet for the thermistor lulzbot includes in their 1.2 hotend.
// What type of sensor is used?
// 1 is 100k thermistor
// 5 is userdefined thermistor table 0
#define EXT0_TEMPSENSOR_TYPE 5
/** Number of entries in the user thermistortable 0. Set to 0 to disable it. */
#define NUM_TEMPS_USERTHERMISTOR0 55
#define USER_THERMISTORTABLE0 {\
{46*4, 270*8*8},{50*4, 265*8},{54*4, 260*8},{58*4, 255*8},{62*4, 250*8},{67*4, 245*8},{72*4, 240*8},{79*4, 235*8},{85*4, 230*8},{91*4, 225*8},{99*4, 220*8},{107*4, 215*8},\
{116*4, 210*8},{126*4, 205*8},{136*4, 200*8},{149*4, 195*8},{160*4, 190*8},{175*4, 185*8},{191*4, 180*8},{209*4, 175*8},{224*4, 170*8},{246*4, 165*8},{267*4, 160*8},\
{293*4, 155*8},{316*4, 150*8},{340*4, 145*8},{364*4, 140*8},{396*4, 135*8},{425*4, 130*8},{460*4, 125*8},{489*4, 120*8},{526*4, 115*8},{558*4, 110*8},{591*4, 105*8},\
{628*4, 100*8},{660*4, 95*8},{696*4, 90*8},{733*4, 85*8},{761*4, 80*8},{794*4, 75*8},{819*4, 70*8},{847*4, 65*8},{870*4, 60*8},{892*4, 55*8},{911*4, 50*8},{929*4, 45*8},\
{944*4, 40*8},{959*4, 35*8},{971*4, 30*8},{981*4, 25*8},{989*4, 20*8},{994*4, 15*8},{1001*4, 10*8},{1005*4, 5*8},{1021*4, 0} } //safety
May 04, 2013 10:55PM
Ladies and gentlemen, we have a winner!
Thank you so much to everyone for helping me out!
Edited 1 time(s). Last edit at 05/04/2013 10:55PM by mgarsteck78.
open | download - Screen Shot 2013-05-04 at 7.52.31 PM.png (82.1 KB)
May 05, 2013 08:18AM
So, what was the solution?
May 05, 2013 01:47PM
The heat table that was proposed above.
