EMC2/Linuxcnc running on Raspberry Pi May 10, 2013 06:54AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 10, 2013 09:15AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 10, 2013 09:41AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 10, 2013 10:57AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 10, 2013 11:28AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 10, 2013 02:14PM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 10, 2013 02:31PM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 10, 2013 02:50PM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 10, 2013 03:28PM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 10, 2013 03:50PM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 11, 2013 07:02AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 11, 2013 09:01AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 11, 2013 09:31AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 11, 2013 12:41PM |
Admin Registered: 19 years ago Posts: 7,883 |
You can drive a Pololu stepper with 3.3V for STEP and DIR, even if the Pololu is running at 5V.
Re: EMC2/Linuxcnc running on Raspberry Pi May 11, 2013 03:08PM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 12, 2013 08:30AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 12, 2013 09:26AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 15, 2013 10:52AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 15, 2013 03:40PM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 15, 2013 04:00PM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 17, 2013 07:34PM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 18, 2013 12:26PM |
mung
You are totally ignoring the whole point of reprap project goals!
mung
If reprap can print more energy then why do you think it cannot print unobtainium???
mung
You do not seem to understand the problems here, it is better to make things simpler then we can have more developers, and once there are more developers they can iterate more faster!
Simple computering makes more iteration quicker, price is irellevant once there is one it will print its self!
Re: EMC2/Linuxcnc running on Raspberry Pi May 20, 2013 07:29AM |
due to the use of some quite high quality connectors and stepper drivers. |
Re: EMC2/Linuxcnc running on Raspberry Pi May 20, 2013 08:38AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 20, 2013 09:00AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 20, 2013 10:46AM |
Re: EMC2/Linuxcnc running on Raspberry Pi May 20, 2013 11:55AM |
Re: EMC2/Linuxcnc running on Raspberry Pi July 21, 2014 03:54PM |
Re: EMC2/Linuxcnc running on Raspberry Pi August 01, 2014 01:56PM |
crob09
If you can install EMC as an OS then you can use the I/O's to interface to a DB25 Driver, or use two I/O's with Arduino as the controller.
Cheers,
Rob
whatisacnc.com
electric-canada.com (new)
