Prusa i3 rods list
Posted by Crux
Prusa i3 rods list
May 12, 2013 06:48AM
Hi.
I am building my first prusa i3. Thanks for this great project!
I am confused on the rods dimensions.
In official Prusa i3 Build Manual it says:
[reprap.org]
X Axis;
2x 470mm 8mm smooth rod
1x 20mm 8mm smooth (for extruder idler, use 8x20 threaded rod or grub screw instead as substitute)
Y Axis:
2x 370mm 8mm smooth rods
2x 400mm M10 threaded rod
2x 400mm M8 threaded rods (M10 is actually correct)
4x 205mm M8 threaded rods
Z Axis:
2x 405mm 8mm smooth rod
2x ~370mm M5 threaded rod
So, should I assume for the Y axis this should be the complete list fot the y axis:
Y Axis:
Why was it changed to M10? In this imae all Y ais threaded rods seems to be same size. Is it really M10?
And are all dimensions correct?
Thanks!
Re: Prusa i3 rods list
May 12, 2013 07:04AM
It's confusing maybe, but yes you need 2x 400mm M10. So your list is correct.
May 12, 2013 07:11AM
im even confused too but i imagine your talking about the box framed version as im building the single frame
and these are
X Axis;
2x 370mm M8 smooth
1x 20mm M8 smooth (for extruder idler, use 8x20 threaded rod or grub screw instead as substitute)
Y Axis;
4x 205mm M8 threaded - Note 210mm for nyloc nuts. If they are cut to exactly the same length will make assembly easier.
2x 350mm M8 smooth - Note take care to cut to exactly same length.
2x 380mm M10 threaded - Note M10 is correct.
Z Axis;
2x 320mm M8 smooth.
2x 300mm M5 threaded (or 320mm if you want it to protrude above the frame).
May 12, 2013 08:56AM
No, I am building a single plate version.
Are this quantities and dimensions correct for this version?
X Axis;
Y Axis:
Z Axis:
May 12, 2013 09:03AM
well the single plate rod are different to my knowledge as im building the single plate and i imagine the extra lengths on the box fram takes in account of the depth of the box frame
May 12, 2013 09:09AM
So, that list is really confused, as those dimensions on official link are for this model, and thats the one i am building smiling smiley
And I already have cutted some rods. Could someone confirm me the dimensions please. Now I am even more confused grinning smiley
Edited 1 time(s). Last edit at 05/12/2013 09:10AM by Crux.
May 12, 2013 09:34AM
the frame is 370mm wide the single plate so the x axis can't be 470 they will stick out read the wiki it tell you two different versions of i 3 spec for your rod lengths
May 12, 2013 09:39AM
ps the side of the picture sub headed Single Sheet Frame Style read that section about the sizes of rod lengths for the single frame
May 12, 2013 09:41AM
whats the link?
could you provide it?
I only see [reprap.org] and it shows same simensions i quoted in previous post.
I am building the Single Sheet Frame Style
is this it?
X Axis;
2x 370mm M8 smooth
Y Axis;
Z Axis;
2x 320mm M8 smooth.
Have you just updated the wiki page?
Thanks
May 12, 2013 09:53AM
no i have updated nothing its been there all the time yes thats the one
May 12, 2013 03:18PM
Dam. Just figured out how stupid I was.
I printed a single selection from the wiki page, and i printed the wrong one. I printed the boxed one.
That was my fault. Thank you for the reply! smiling smiley
