changing the size of an object
May 13, 2013 05:19AM
Hey I want to print the falcon Maltese, but its too big, so I want to change the size to 50 procent. How or where do I do it in slic3r, pronterface or repetier host.
Best regards
Re: changing the size of an object
May 13, 2013 05:24AM
You do that in slic3r
Select the "Plater" tab and load your file
Then select "Scale" and enter the value in %
Then slice it by selecting "Export G-Code" smiling smiley
Regards
Jan
May 15, 2013 10:28AM
Thanks for your answer I figured it out. my slic3r software was just to outdated for such solutions. thanks!
May 15, 2013 02:16PM
Since you've mentioned Repetier-Host, you can also scale directly in the 3d view. Another handy feature I use with long narrow objects is the Rotate around Z axis. It allows you to fit longer objects diagonally on the bed, squeezing every last mm out of the space! smiling smiley
Edited 1 time(s). Last edit at 05/15/2013 02:17PM by NumberSix.
