Endstops always on
Posted by jininjin
Endstops always on
May 16, 2013 11:47PM
I have just wired up my Ramps 1.4 to my Prusa and I am finding all endstops are triggered on by default. If I hold one of the endstops it allows the axis to move. Do I need to rewire or can I switch something in the configuration.h file? I tried the x_endstops_inverting false and that did not work....
Any Suggestions?
Re: Endstops always on
May 17, 2013 06:24AM
Wire the endstops to N.C and Common.
May 17, 2013 12:03PM
I agree they should always be wired normally closed. That way if one wire becomes disconnected it will stop instead of trashing your reprap. Happy building.
--------------| For Everything |--------------------------
Check it out here:
[reprapsquad.wordpress.com].
---------| For Everything Prototype Related |------
Now featuring comp case mods:
[RepRapLab.wordpress.com]
--------------| Find us at Twitter|------------------------
@REPRAPSQUAD (RS Main)
[mobile.twitter.com]
@REPRAPSQUADHQ (ProtoLab)
May 17, 2013 01:09PM
> Happy building.
This is true as long as you have the firmware set to only use endstops for homing. Otherwise an NC switch that opens up during a print would cause a disaster, as that axis would start to only move in one direction.
May 17, 2013 08:10PM
Thanks, I am not sure how I messed that up. I will try again.
