single sided board
Posted by ZachHoeken
single sided board
February 10, 2007 09:19PM
i'm failing pretty badly at doing 2 sided boards with toner transfer. the alignment is killing me. i would love to have a 1 sided board that i can just print and drill... super easy.
anyway, i'm basically a novice at this, so i'm going to give it a try tomorrow... who knows!
sai
Re: single sided board
February 10, 2007 09:27PM
Have you tried using two separate printouts, rather than a folded one?
Etch only one side, and then use drill holes to align the second side.
February 10, 2007 09:52PM
ah!
i see what you're saying. i'll do toner transfer, drill alignment holes, transfer again, then etch!
its a good thing erasing bad toner transfers is that you're only a solvent away from a fresh board.
