Making moulds from PLA prints?
Posted by danlad1631
May 29, 2013 01:56PM
Is there a way to create a smooth mould from a PLA print?
Is there a way to fill in the lines then cast a mould?
Thanks
Re: Making moulds from PLA prints?
May 29, 2013 04:45PM
With ABS I use a product called glazing or spot putty. It's used to fill small scratches in automotive paint before repainting. I then sand it smooth and then you can make a mold with silicone.
I would assume you could do the exact same with PLA.
May 29, 2013 04:59PM
You can use a technique called 'Vapor Treating'.
Read about it here:
[blog.reprap.org]
(Only usable on ABS!)
Edited 1 time(s). Last edit at 05/29/2013 05:00PM by Ohmarinus.
May 29, 2013 06:53PM
Vapor treating is great but you can lose fine definition. If the model is complex with small detail best to do it with spot putty as it will just fill in the lines without losing fine detail.
It's more work, but gets the job done. And vapor as you mention is for ABS only while the OP specified PLA.
