HELP- Rostock 3D printer end stop
Posted by haageen
May 29, 2013 05:13PM
Hi
I have just builded my rostock 3d printer. Finaly I have all axis configured right. When using pronterface and live drive all axis are moving correctly. But I have som serious problems with the end stops.
Please Help
The Y axis is ok. when homing this axis it stops and make a little jump as supposed to. But the other axis does not work. When homeing its like the motors neclect avoiding the endstops. How can i "turn it on" and get it to behave as y-axis
I have no min endstop and have turned it off
//=============================Mechanical Settings===========================
// Uncomment the following line to enable CoreXY kinematics
// #define COREXY
// corse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
// fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined
#define ENDSTOPPULLUP_XMAX
#define ENDSTOPPULLUP_YMAX
#define ENDSTOPPULLUP_ZMAX
//#define ENDSTOPPULLUP_XMIN
//#define ENDSTOPPULLUP_YMIN
//#define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Y_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Z_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
//#define DISABLE_MAX_ENDSTOPS
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruders
#define INVERT_X_DIR true // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define min_software_endstops true //If true, axis won't move to coordinates less than *_MIN_POS.
#define max_software_endstops true //If true, axis won't move to coordinates greater than *_MAX_POS.
#define X_MAX_POS 90
#define X_MIN_POS -90
#define Y_MAX_POS 90
#define Y_MIN_POS -90
#define Z_MAX_POS MANUAL_Z_HOME_POS
#define Z_MIN_POS 0
#define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS)
#define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS)
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
// The position of the homing switches
//#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used
#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0)
// Manual homing switch locations:
// For deltabots this means top and center of the cartesian print volume.
#define MANUAL_X_HOME_POS 0
#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS 400 // Distance between nozzle and print surface after homing.
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {100*60, 100*60, 100*60, 0} // set the homing speeds (mm/min)
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 80, 1100}
#define DEFAULT_MAX_FEEDRATE {300, 300, 300, 45} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {9000, 9000, 9000, 300} // X, Y, Z, E maximum start speed for accelerated moves.
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 300 // X, Y, Z and E max acceleration in mm/s^2 for r retracts
#define DEFAULT_XYJERK 20.0 // (mm/sec)
#define DEFAULT_ZJERK 20.0 // (mm/sec)
#define DEFAULT_EJERK 2.0 // (mm/sec)
Re: HELP- Rostock 3D printer end stop
May 29, 2013 05:29PM
When hitting home X axis it is the Z axis that moves, and opposite. But still when pushing the X axis on pronterface it is the x motor that moves???
How to fix this? Ideas
I have checked all cables towards towards the arduino ramps 1.4 board and also that the X axis motor has the x axis end stop and so on.....
May 29, 2013 05:59PM
If you use M119 to check the status of the endstops, then press each switch manually and execute M119 do the results look good?
What electronics are you using?
___________________________________________________________________________
My blog [3dprinterhell.blogspot.com]
May 30, 2013 05:30PM
Hi
When doing the m119 comand the endstops is active when pushed and not active when released
I have a mechanical endstop connected to my ramps 1.4 card.
When using pronterface program i can push home on the i axis. It does not work on the other axis. The printer goes toward xmax but endstop is on the opposite side but is connected to xmax on the card.
Edited 1 time(s). Last edit at 05/30/2013 05:32PM by haageen.
May 30, 2013 05:45PM
You do realize that for at least older versions of Marlin only G28 works to home, you can't home individual axis?
