If you need 2mm of retraction distance then... June 01, 2013 02:43PM |
Re: If you need 2mm of retraction distance then... June 01, 2013 05:03PM |
Re: If you need 2mm of retraction distance then... June 02, 2013 07:36AM |
Re: If you need 2mm of retraction distance then... June 02, 2013 07:42AM |
Re: If you need 2mm of retraction distance then... June 02, 2013 02:12PM |
thejollygrimreaper
the big problem i think all of us have now is that there is no feedback from the extruder as to how much back pressure/resistance there is until it's too late, so at the moment we cannot measure and test for upper and lower limits of this speed band,
Re: If you need 2mm of retraction distance then... June 02, 2013 03:18PM |
Re: If you need 2mm of retraction distance then... June 02, 2013 05:57PM |
Re: If you need 2mm of retraction distance then... June 03, 2013 10:13AM |
Jasper1984
Note: this post is very incomplete. See if i can make a model and a way to actually fit it to data. Why do you think the force climbs slowly?
Re: If you need 2mm of retraction distance then... September 03, 2013 03:09AM |
Re: If you need 2mm of retraction distance then... September 03, 2013 07:38AM |
Re: If you need 2mm of retraction distance then... September 03, 2013 07:25PM |
Re: If you need 2mm of retraction distance then... September 04, 2013 02:14PM |
Re: If you need 2mm of retraction distance then... September 04, 2013 11:03PM |
