Re: 3D cement printer December 20, 2013 06:14PM |
Re: 3D cement printer December 20, 2013 07:20PM |
Re: 3D cement printer December 20, 2013 07:37PM |
Re: 3D cement printer December 21, 2013 02:16PM |
AndreyR
After several months of experimentation, I finally made a custom extruder which works in the way it needs to for the cement printer (stable on any speed). This was not an easy task, and I made 5 different versions before the current working one. In the photo, you can see the very first print. Unfortunately, my garage workplace is close to freezing right now, and it would be hard to print several layers in one trial. But it will be even more interesting to experiment with cold conditions. I hope to be able to make these prints within the week, and when I do, I will post pictures or videos of my final results.
Thus, the first version of the prototype is done, with the prototype working just fine. My idea to make a cement printer based on the Rep Rap project and using attainable parts has finally become a reality.
Now on to version two.
Re: 3D cement printer December 22, 2013 02:04PM |
JamesNewton
hackaday has an interesting article about Paste extruders including concrete:
http://hackaday.com/2013/10/16/3d-printering-pastestruders/
A2
Have you explored using a Moineau pump?
Re: 3D cement printer December 22, 2013 02:37PM |
jb92563
This is great stuff your doing but I'm curious how you handle the two conflicting requirements of:
1) The cement needs to be fast setting so you can build up layers taller without collapsing the earlier layers because they have not set yet.
2) The cement should have enough working time so that it can move through the extruder without altering the flow
rate or blocking up the extruder pasages.
Re: 3D cement printer December 22, 2013 05:16PM |
AndreyR
I don't know of any cement mixes with an extremely short setting time.
My biggest problem at the moment is pushing the cement through the pump with its high viscosity.
Re: 3D cement printer December 22, 2013 06:55PM |
A2
AndreyR
Calcium aluminate accelerates the hardening of Portland cement, which allows you to mix a watery slurry.
Look at the links I posted above.
Maybe you could pump it by adding calcium aluminate to help it harden/cure faster?
To prevent the wall from slumping, extrude a multiple layered wall with a small diameter extrudate.
Video, go to 1 min, he mixes a soupy/watery batch of concrete with calcium aluminate, and it sets in ~3 min.
[www.youtube.com]
Re: 3D cement printer December 22, 2013 10:09PM |
Re: 3D cement printer December 22, 2013 11:46PM |
Re: 3D cement printer December 23, 2013 06:40AM |
Re: 3D cement printer December 23, 2013 07:59AM |
Re: 3D cement printer December 25, 2013 01:24PM |
johnrpm
The following idea is published under the LRC licence, it is free for all personal use
For commercial use, who owns the license, the concept outlined has been around for at
least 15 years to my knowledge.
Re: 3D cement printer December 26, 2013 12:13PM |
Re: 3D cement printer December 27, 2013 02:32AM |
Re: 3D cement printer December 27, 2013 03:06AM |
Re: 3D cement printer December 31, 2013 06:09PM |
Re: 3D cement printer January 01, 2014 11:52AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: 3D cement printer January 02, 2014 05:18PM |
A2
WOW!
Can I send you a CAD file of the Dutch hot tub!
Re: 3D cement printer January 02, 2014 07:26PM |
JamesNewton
That is just neat! Congratulations!
What are you going to do for a version 2? How big? What do you think you will need to drive it? Let me know if I can help.
Re: 3D cement printer January 02, 2014 07:38PM |
Re: 3D cement printer January 02, 2014 11:55PM |
Re: 3D cement printer January 03, 2014 10:06PM |
AndreyR
But I cannot use CAD files for the cement printer yet because Slic3r has made things more complicated
for simple design like a box, tub or even wall, and I have to program g-code manually, like 50 years ago.
Re: 3D cement printer January 04, 2014 06:59PM |
Re: 3D cement printer January 04, 2014 10:18PM |
PulsedMedia
Amazing project!
Simply awesome!
On the curing, why not try heat? Lots of heat.
You could put a heat gun or two blowing at the tip of the nozzle from 2 sides, or 4 at each side, that way you get some heat applied to cement coming up ahead and on the wake of just extruded.
As i understand, cement cures in function of water "leaving" it, ie. that means heat + air circulation is the quickest means to lower the relative humidity of the surrounding air and thus more water is getting out of it faster, ie. faster curing. Is this correct?
Also as heating would be easily controllable
You could also have on each side some IR heating lamps increasing temperature all around your print for faster curing.
This project gave me some ideas for my extra large plastic printer.
Re: 3D cement printer January 05, 2014 11:54PM |
A2
I'll design you a Dutch hot tub
What is the wall thickness, and the actual layer height?
That will help me design the Dutch hot tub so you don't have to compromise your slicing.
How many person, or would you like the design to be near the size of the original?
About 10 years ago I designed a Dutch tub after the original, but I modified the interior walls.
The walls were curved to put near zero stress on the lower bones of the back.
The numbers came from an engineering ergonomics book, and from my studies of airplane seat designs for cross country flights.
This modification will increase the diameter.
I'll work with you on the design. I'll need to know what some of the limitations of the bot are.
For example, the legs supporting it, might it be easier to add them after the main tub has been formed.
When you're ready let me know, I understand that you are still in the experimental stage.
I'm sure someone reading this thread will know of a slicer workaround so you don't have to hard code thousands of way points.
JamesNewton
But it looks like the DC motor works ok for you... why change?
Re: 3D cement printer January 06, 2014 04:11AM |
Re: 3D cement printer January 06, 2014 12:45PM |
AndreyR
JamesNewton
As you can hear in the video, the rotation speed/RPM varies because the cement mix is not the same consistency throughout the entire extrusion and that's the major source for the discrepancy in the layers' width. And as you can see, the extrusion speed need to be reduced on the corners. Thus, a step motor has to be involved. I'm thinking I need about a 1000w step motor, but one that is as compact and light as possible.
Re: 3D cement printer January 09, 2014 12:30PM |
JamesNewton
AndreyR
JamesNewton
The regulation of your existing extruder motor should be quite possible with something like my friend Roman's "SuperPID". It's more or less the same as controlling the speed of a cutter on a CNC machine and that is exactly what a PID does. You can change the speed programmatically via PWM or other signals from the controller. That is fully supported by G-Code in general, but I'm not certain it is supported by your current breakout hardware. It certainly isn't supported by Pronterface, so you would have to switch to Mach 3, or EMC2. They should still be able to accept G-Code from Slic3r or whatever, but you may need to pre-process it to change the encoder step codes into spindle speed codes.
Re: 3D cement printer January 09, 2014 02:57PM |
