Advice on mk7 gear set screw problems
Posted by Enlightx
June 21, 2013 03:54PM
Hi guys ths problem s doing my head in
I'm using i3 extruders that use the mk7 gear pully to grip the filament
The problem I have is my stepper motor skips , filament stirs and skips the lot
I rip the extruder out and look at the gear and the hobbled gear has worked only a bit loose and moves around 1mm on the 5mm bolt
I have problems getting the m3 set screw to old good.
When I tighten down n the set screw I either round off the screw or the hex key.
If also tried tread lock
Only thing I can imagine is te m5 hex head bolt s soft metal and thats the problem
Any advise??
Re: Advice on mk7 gear set screw problems
June 21, 2013 07:30PM
the best grub-screws are the black case hardened ones, the sorface finish helps it stay in there
-=( blog )=- -=( thingiverse )=- -=( 3Dindustries )=- -=( Aluhotend - mostly metal hotend)=--=( Facebook )=-
June 22, 2013 08:10PM
I grind a flat spot on the motor shaft where the set screw will set on it.
Rodney
June 23, 2013 12:07PM
yeah this is sitting on a M5 bolt as its the I3EXT extruder
i think iv got it solved now i went and blew £25 on a set of wera hex keys.
seemed to solve the problem..... so far
