LM8UU VS IGUS
Posted by Enlightx
Re: LM8UU VS IGUS
January 22, 2015 12:08PM
To be honest I have over 300 hours on my chinese bushings. They are louder than the printed bushings I have. However I found that packing them with grease before installing helped. I feel they have lost some tolerance since new but not much. On my end effector rebuild I am contemplating printing ABS bushings then machining the right size to get rid of the print ridges. However I believe I can use synthetic axle grease to prolong their wear as well as include a grease port on the bushings to make maintenance much easier. I have greased my ball bearings every 50 hours of work. Its messy but it keeps the printer working smoothly.
My Personal Blog. Build blog.
[engineerd3d.ddns.net]
Modicum V1 sold on e-bay user jaguarking11
Re: LM8UU VS IGUS
January 22, 2015 01:35PM
50 hours is to me less than 4 days. I can't dismantled my printer that often. What a waste of time ! Igus Drylin bushings are 3 times more expensive than chinese LM8UU. On the 12 chinese bearings I own, only 8 was fully functionnal. I could deal with it, with grease and ear plugs. But why ? Igus bushings just works. you install it and you leave it. Perfect results first time, anytime. What more would you like ?
Collective intelligence emerges when a group of people work together effectively. Prusa i3 Folger (A lot of the parts are wrong, boring !)
Re: LM8UU VS IGUS
January 22, 2015 05:12PM
I do not disassemble my printer for maintenance, packing was for the first install. I will be replacing the bushings after I am done making all new parts to go with my igus ball joints. I simply use a small brush and brush on some grease on the rods themselves. The bearings pick them up nicely and all is done. As for noise, I have to say the loudest parts of my printer are the motors. Other than that its actually a fairly quiet printer. I am considering reusing my old ball linear bearings with the new parts I am making for this printer (end effector and carriages and rods)....
Re: LM8UU VS IGUS
January 22, 2015 05:23PM
If you're delight with LM8UU, it's fine to me. The LM8UU are sealed, that means they have a rubber lip that prevent any dust or anything, like grease, to comme in. If you want to grease them I'm affraid you need to unmount them...
Re: LM8UU VS IGUS
January 23, 2015 10:31AM
Zavashier
The rods themselves are not chrome, they are drill bit rod if I recall correctly. That means they have a bit of a grain to them. Simply brushing some grease on the rods has made a fairly good difference. At least to me they have. I never said I am delighted by my bearings, what I am saying is that mileage will vary with these parts. I still would like to build my own glide surfaces. I am also looking at bearings that have a side nipple in them at this time so I can attach a grease gun to them.
Re: LM8UU VS IGUS
January 23, 2015 03:32PM
I understand better winking smiley
Re: LM8UU VS IGUS
April 05, 2016 03:03AM
Hello all guys how are you? anyone present here.
Re: LM8UU VS IGUS
January 12, 2017 07:04PM
Did anyone have to change their xy jerk settings with the igus bearings
Re: LM8UU VS IGUS
January 16, 2017 08:49PM
fargkenob
I am using them on x and y, haven't changed anything and i like them.
