Image to 3D June 28, 2013 07:50PM |
Re: Image to 3D June 28, 2013 10:06PM |
I use FreeCAD which has a complete GUI my non-programmer brain can understand. It can import SVG very well. The DXF was a no-go in FreeCAD because it is made out of spline curves and the DXF importer does not support splines. LibreCAD could open the DXF fine BTW. No idea if OpenSCAD could import it.
Re: Image to 3D June 29, 2013 03:47AM |
Admin Registered: 15 years ago Posts: 730 |
Re: Image to 3D June 29, 2013 03:49AM |
Re: Image to 3D June 29, 2013 04:21AM |
MattMoses
That's a nice method, NormandC, I hadn't seen one using FreeCAD before.
rhmorrison
Inkscape can convert those spline curves to line segments.
Re: Image to 3D June 29, 2013 06:25AM |
NormandC
Except you loose much quality when converting from spline curves to line segments. Your outline will be jagged. Granted it might not matter for 3D printing but I'm kind of a purist. Also if you ever want to have it laser cut in another material (steel, aluminum...) it won't look good.
Re: Image to 3D June 29, 2013 04:46PM |
Re: Image to 3D June 29, 2013 05:02PM |
rhmorrison
you add additional points so that the quality is more than needed (at least for 3d printing which is what this forum is about).
Re: Image to 3D July 01, 2013 07:34PM |
Re: Image to 3D July 02, 2013 01:26PM |
