SLIC3R into Pronterface
Posted by mondo50m
July 15, 2013 11:45PM
The pronterface copy that I have is presently running version 7.1 of Slic3r. How can I get the newest version to run with Pronterface. It may be necesay to give me clear instructions as I am 62 years old and not very computer literate. Any help is appreciated.
MIlt
Re: SLIC3R into Pronterface
July 16, 2013 10:00AM
Pronterface runs slic3r from it's own directory as default, this will most likely be something like C:\Program Files\Pronterface\Slic3r
Just rename this to something like Slic3r_old, and copy the new version of Slic3r to the Pronterface directory.
But after Slic3r started having selectable presets for slicing settings, I found that it is better to just start Slic3r, slice , export, and then just load the gcode in Pronterface, as the presets isn't supported in Pronterface, at least not in the version I'm using.
July 16, 2013 10:21AM
Thank you very much for the response. I will do it your way. Slice, the save the gcode.
Milt
July 16, 2013 08:42PM
the other benefit to doing it that was is that you can check your gcode on sites like this http://gcode.ws/
and yes the pre sets are very handy
