Another question about Repetier
Posted by mondo50m
July 24, 2013 10:37AM
I have downloaded the Recorder Flute from thingiverse. Section 3 is too tall to fit withing the constraints of my printer. I am trying not to print it lying down as this would create a 'flat spot' on a section of the flute. There is a function in Repetier that says cut. I see how the actual positioning of the cut works. But, does anyone know, once you have configured the cut, how to make it the only part that will print? When I slice the cut part, the whole flute section gets sliced. I need to have the section 2 in two pieces.
Milt
Re: Another question about Repetier
July 24, 2013 10:39AM
There is a dedicated forum for Repetier Questions:
[forums.reprap.org]
July 24, 2013 03:35PM
So sorry!!
July 24, 2013 04:08PM
Cut in Repetier is only a visualization aid. It does nothing to the model mesh itself. You can do real mesh cutting in netfabb with ease though.
July 24, 2013 04:30PM
Swoozle--thank you very much. Once I knew it was available, it was really simple. Again, thank you.
Milt
