Almost there, Z lifting .44 July 25, 2013 12:19PM |
\Mendel_Reprap\stl\0.5mm-thin-wall_export.gcode It took 51 seconds to export the file. 0 mm of filament used in this print the print goes from 74.979000 mm to 105.006000 mm in X and is 30.027000 mm wide the print goes from 74.981000 mm to 185.000000 mm in Y and is 110.019000 mm wide the print goes from 0.441000 mm to 9.891000 mm in Z and is 9.450000 mm high Estimated duration (pessimistic): 22 layers, 00:06:42 Extruding 1.000000mm of filament.
Re: Almost there, Z lifting .44 July 25, 2013 02:28PM |
Re: Almost there, Z lifting .44 July 25, 2013 05:05PM |
Re: Almost there, Z lifting .44 July 26, 2013 03:39AM |
Re: Almost there, Z lifting .44 July 27, 2013 05:50PM |
