Any way to mirror a print?
July 28, 2013 02:05PM
I am trying to mirror a print. I am using slic3r or KSSlicer, and either repetier or pronterface.
I don't see any way to mirror in any of those.
My design is in openscad, so if there is even a way to do it there it would be great too.
Thanks!
Re: Any way to mirror a print?
July 28, 2013 03:10PM
If I remember correctly ReplicatorG was able to do that. I think you might be able to mirror and save as a new STL as well.
July 28, 2013 03:40PM
Thanks. I actually found there is a mirror function in openscad, so that is working perfectly for me.
July 28, 2013 04:34PM
There's probably a mirror function in meshlab too if you don't have openscad source.
July 30, 2013 08:53AM
Netfabb will do it as well
Regards
Jan
[3dprinting4u.wordpress.com]
July 30, 2013 08:56AM
Thanks everyone.
Since my design was in openscad, the mirror function in openscad got me exactly what I needed.
I will keep this in mind if ever dealing with an stl that I did not design myself.
Thanks!
July 30, 2013 02:44PM
flip your y or x motor around or set firmware to invert in the direction needed.
July 30, 2013 02:48PM
If you'd have the model avialable ( step / STL OBJ) I could flip it for you
July 30, 2013 03:32PM
Oh, and the current version of KISSlicer also has a mirroring capability, just right click the object in the top right column and it's in the.drop down that appears.
July 30, 2013 09:49PM
CURA will also mirror objects.
