5V pin on ramps 1.4 to power Thermocouple board ?
Posted by flying freak
July 29, 2013 08:32PM
Hello,
Just curious what pin could be used on the ramps boared to power this board : [reprapworld.com]
Im not using a computer power supply so cant pull right from there.
Steven
Re: 5V pin on ramps 1.4 to power Thermocouple board ?
July 31, 2013 12:01AM
In the reprapworld.com link you provided, the description includes the following:
"For more information on installing and configuration, see the wiki [reprap.org]"
The information there is what you need. The connection they suggest is on AUX1 which is sourced from the underlying ArduinoMega, so whatever you have that lights up your Mega is going to do it for your thermocouple board as well. There are other places on the RAMPS to pick up the voltage if that particular connector is inconvenient (other AUXs, I2C, Servo), so check the schematic for those.
Mike
July 31, 2013 10:07AM
I had seen that quickly sorry should have been more specific.
I'd like to run 2 of these and feed the signal back into T1/T2. Headers.
I'm assuming this might not be possible? Would you set the second unit into aux 2?
Steven
