Looking to make a custom sized heated build pcb - help?? August 02, 2013 05:16PM |
Re: Looking to make a custom sized heated build pcb - help?? August 03, 2013 04:38AM |
Re: Looking to make a custom sized heated build pcb - help?? August 03, 2013 05:36AM |
Re: Looking to make a custom sized heated build pcb - help?? August 03, 2013 09:10AM |
Re: Looking to make a custom sized heated build pcb - help?? August 03, 2013 09:44AM |
Re: Looking to make a custom sized heated build pcb - help?? August 03, 2013 09:57AM |
Re: Looking to make a custom sized heated build pcb - help?? August 03, 2013 11:47AM |
Re: Looking to make a custom sized heated build pcb - help?? August 03, 2013 12:17PM |
Re: Looking to make a custom sized heated build pcb - help?? August 03, 2013 04:37PM |
Re: Looking to make a custom sized heated build pcb - help?? August 11, 2013 04:04PM |
Re: Looking to make a custom sized heated build pcb - help?? August 11, 2013 05:14PM |
Re: Looking to make a custom sized heated build pcb - help?? August 11, 2013 05:22PM |
Re: Looking to make a custom sized heated build pcb - help?? August 11, 2013 07:59PM |
Re: Looking to make a custom sized heated build pcb - help?? August 11, 2013 09:58PM |
Re: Looking to make a custom sized heated build pcb - help?? August 11, 2013 10:49PM |
Re: Looking to make a custom sized heated build pcb - help?? August 11, 2013 11:00PM |
Re: Looking to make a custom sized heated build pcb - help?? August 12, 2013 03:35AM |
Re: Looking to make a custom sized heated build pcb - help?? August 12, 2013 02:24PM |
) but I can only reasonably sustain 110C to 120C throughout the print. The bed also heats up really fast (up to 120C in about 5mins with cardboard insulator). If you are looking to print a lot of Polycarbonate or even Nylon, a higher power heat bed would be beneficial. One major problem with the RepRap electronics is that the heat beds are notoriously underpowered. Even if you can reach 120C on a Prusa PCB heater, it is not powerful enough to provide stable heating throughout the print. In addition, the resistance of the copper clad PCB Heaters is not as accurate. Before I started using Silicone Rubber Heaters, I had problems with my Prusa PCB dropping to 80C during the print!
I also have sheet glass that is 270mm x 270mm x 2mm and 270mm x 270mm x3mm which would be perfect for these heat beds. Let me know if you are interested
Re: Looking to make a custom sized heated build pcb - help?? August 13, 2013 01:15PM |
Re: Looking to make a custom sized heated build pcb - help?? August 13, 2013 03:05PM |
What type of cartesian movement system are you using? Are you going to have a non-moving bed? 300mmx300mm bed would be quite heavy with a sheet of glass on top so the standard moving bed mendel design doesn't seem like the optimal set up as it may limit your acceleration/speed.|
Re: Looking to make a custom sized heated build pcb - help?? August 13, 2013 04:02PM |
bewteen two options for heatbed :|
Re: Looking to make a custom sized heated build pcb - help?? August 13, 2013 04:51PM |
The bed fuse is rated at 16V 11A... I got around this by simply replacing the bed fuse with a 32V 30A rated fuse from Digikey. These are expensive but they do the job. If you decide to order the heat beds from me I can ship one of these fuses together with your heat bed for an extra 6 bucks (it will save you from the minimum shipping fee for ordering from Digikey).|
Re: Looking to make a custom sized heated build pcb - help?? August 13, 2013 06:26PM |
Re: Looking to make a custom sized heated build pcb - help?? August 13, 2013 08:09PM |
) These pictures are of my modified Prusa set-up and illustrate the heated bed mounting.
When you are adjusting 4 points in a plane adjusting one point affects the position of the others. As a result, bed leveling becomes an iterative process where you have to continue to adjust each point over and over again until your bed is sufficiently level. On the other hand, with the 3 point system you only have to adjust each point once (only 3 adjustments
) This makes sense as any 3 points in space will define a plane yet any 4 points may or may not define a plane. Anyway, I use 2 sheets of 6.5mm MDF connected by 3 bolts (with springs). The MDF sheets have pieces cut out (not solid) to save on weight while maintaining structural integrity. This design has many advantages: 3 point leveling, lightweight, sprung bed (safety for the nozzle crashing into the bed
, bearing holders are completely thermally isolated from hot bed, and wing nuts allow for very easy 2 second bed leveling
for printing ABS parts. With a thin clear garbage bag around my printer and the bed temp set to 90C the chamber temp reaches about 40C. If you wanted to print Nylon or Polycarbonate with higher bed temps and thicker clear garbage bag insulator, then you could probably reach up to 60C chamber temp...which happens to be above the glass transition temperature of PLA
So any PLA parts within the high temp "garbage chamber" would start to get rubbery and generally wear quickly and fail
I understand that people have a hard time printing ABS, but PLA really isn't suited for printer parts. BTW I have come up with a set up that completely (and reliably) eliminates ABS warping and results in much stronger parts but I don't want to go into details here as I think that would take us too far off topic. If anyone is still having problems with ABS let me know and I can start a new thread about this.
If you are interested, all I would need would be a dimensioned CAD drawing or rough sketch of the position of the mounting holes for the bearing holders and y axis belt. I may not have time to do this for you but I can try if you are interested. |
Re: Looking to make a custom sized heated build pcb - help?? August 14, 2013 12:47AM |
Re: Looking to make a custom sized heated build pcb - help?? August 14, 2013 01:26AM |
) : [devel.lulzbot.com] .
Re: Looking to make a custom sized heated build pcb - help?? August 14, 2013 01:39AM |
Sorry about that. If you want I can get you a silicone rubber heater that is 13"x10" but I really don't know where you will find a PCB heater that size.
I can't really tell from the render but is the y-axis motor inside the chamber? It looks to me like the only motor that needs to be inside the chamber is the extruder motor, which will probably get really hot seeing as it will be directly above the heat bed
You may want to consider a fan with ducting to pull cold air from outside the chamber to cool the stepper. I have fans on all my steppers inside the garbage chamber at 40C and they are still pretty hot (though there has not been a noticeable decrease in performance). As for the enclosure, you could easily get away with acrylic windows rather than using polycarbonate. Since the fame is made of MDF, the windows are not structural components so the minor warping that acrylic will experience at those temps will not distort the frame. In this case, the extra cost of polycarbonate would not be worth it in my opinion.
Re: Looking to make a custom sized heated build pcb - help?? August 14, 2013 02:48AM |
Sorry about that. |
Re: Looking to make a custom sized heated build pcb - help?? August 14, 2013 06:31AM |
You
Re: Looking to make a custom sized heated build pcb - help?? August 14, 2013 08:14AM |
Sorry
