need a hot end
August 07, 2013 01:27PM
Looking for a reccomendation for a good hot end ?
Ive been using the jhead mkiv-b but just not happy with the results I've been mostly printing with abs but would like to also try nylon and wood filament ?
Re: need a hot end
August 07, 2013 02:14PM
E3D V5
Re: need a hot end
August 07, 2013 02:57PM
+1 for E3D.
If you are willing to wait a little bit and pay less, I'm currently working on a more economic all metal hotend.
Re: need a hot end
August 07, 2013 03:51PM
If money is no object, get prusa's all metal hotend .
Re: need a hot end
August 07, 2013 03:54PM
> hotend .
I don't mind paying more for quality yet at the same time I'm not overpaying for something so simple.
I've honestly been reading about thr prusa nozzle and its overpriced in my opinion
Re: need a hot end
August 07, 2013 04:03PM
> hotend .
Prusa's V1 is inconsistent and has significant design issues. So much so that the next version appears to be an E3D copy to correct the issues in the first version.
Re: need a hot end
August 07, 2013 04:09PM
I'm considering the e3d I'm also trying to change my whole setup I'm getting really tired of spending more time cleaning chewed up filament from my hobbed bolt and less time printing
Re: need a hot end
August 07, 2013 10:41PM
Are you sure the issue is with the hotend? I have the same hotend you do (from hotends.com), it doesn't jam and prints beautifully. Your j-head should not jam, especially with ABS.
If you are getting jams so bad that the filament is chewed up, you are probably just printing at a very low temperature.
Make sure that you have the correct thermistor setting in your firmware. If still jamming, raise the printing temperature.
Try Sublime's Tantillus calculator, it tells you what temperature to print at (the calculator is for the Tantillus printer, but it should give you a good idea of what temperature to use based on nozzle size, speed and layer height).
Edited 1 time(s). Last edit at 08/07/2013 10:42PM by lajos.
Re: need a hot end
August 07, 2013 10:57PM
I will double check it worked fine for a little while then it just started jamming I cleaned it I'm going to swap out a spare brass nozzle I've been printing at 220
