BUilding Prusa Air 2 - Frame dimension for laser cutting
Posted by kidearth
August 10, 2013 08:33AM
HI,
Currently I am attempting to build my Prusa Air 2. While I am looking around for a laser cutting service in my area (singapore), I am having problems trying to get the dimensions for the prusa air 2 frame. I looked at several of the design files (dxf) posted in thing universe, however, have been unable to determine what is the frame dimension. The files posted in [www.thingiverse.com] does not state the scale/dimension and I am unable to determine the frame dimension on [www.reprap.org] as the images posted was quite unclear.
Appreciate if someone can share their experience with me. Thanks.
Re: BUilding Prusa Air 2 - Frame dimension for laser cutting
August 11, 2013 08:23PM
The dxf from the thingiverse link is in mm. If you are in doubt you can guide your self by the mounting holes for the nema 17 and check if they have the correct dimension.
But that link is to Prusa Air not Prusa Air 2:
Cheers
August 13, 2013 03:28AM
Hi pdesigns,
thanks.
