UConduit H-Bot 3D Printer / Reprap
Posted by iquizzle
August 17, 2013 08:16PM
Hello all,
Some of you are probably already aware of this printer from hackaday or the thingiverse page. I thought I'd also make a forum post for those who frequent these forums.
The UConduit is a 3d printer built with a frame that uses standard electrical conduit like the stuff you'd find at the hardware store. I wanted a printer that went back to the hardware store roots of the prusa i2, but with an h-bot design that uses no moving motors for a lightweight gantry, much like the ultimaker. The printer is fully open source (github) and designed using open source tools (OpenSCAD). It's easy to scale (in fact, someone has already made a jumbo version of it (here) with 410mm build area per side). The build volume of the standard printer is ~250mm on each dimension.
Since it's initial release, I've added a BOM and an interactive full SCAD model of the printer. A build guide should be coming along soon as well.
Here's a video of mine printing an octopus: http://www.youtube.com/watch?v=73MlaBWCTPU
I'll add more videos soon, but I've been busy busy busy! Anyway, I hope you enjoy it. You can join the fun, ask specific questions or post your own h-bot/corexy designs on the google group.
Edited 1 time(s). Last edit at 08/17/2013 08:18PM by iquizzle.
open | download - UConduit_full.png (60.5 KB)
Re: UConduit H-Bot 3D Printer / Reprap
August 17, 2013 11:23PM
Looks very nice. I might have to build one of these for my next printer.
Edit: Looks perfect for a dual (or quad spinning smiley sticking its tongue out) bowden extruder setup.
Edited 1 time(s). Last edit at 08/17/2013 11:48PM by NewPerfection.
August 18, 2013 11:37AM
Yes! Dual extruders is what I plan on doing next. I've had some positive success with bowden so far. I like it as an extruder platform for exactly this reason. Bowdens are more challenging to get tweaked just right, but they do have a payoff in several ways once you get them to work.
August 18, 2013 04:22PM
My dad is wanting me to build a laser cutter/engraver for him as well, using a high-power fiber laser. This platform looks ideal for that as well, especially because it could be easily enclosed and doesn't have a table moving in x or y. If I do end up doing that project, I will definitely share my process and results.
August 18, 2013 09:38PM
That would be awesome! If you do it, I'd like to hear about it. I'd like to have one myself.
August 18, 2013 11:26PM
I'm not 100% sure on the platform I'd be using, I'm still researching that. The fiber lasers that I'm looking at look fairly straight forward to control, just using TTL-level signals to control power, frequency, on/off, etc. Some modification to RepRap firmware will be required, but should be relatively straight forward. I will definitely start a thread here if I start work on it.
August 19, 2013 01:25AM
Ive been printing out the xy axis this weekend, for a tslot project Im doing. I like it so far, light and rigid enough
August 19, 2013 06:27PM
Have you found any fiber lasers that are reasonably priced? Every time I check out ebay it's like $3k for a 200mW laser.
NewPerfection Wrote:
> to
August 19, 2013 06:37PM
The laser is gonna cost a lot, I'm looking at about a 100W laser for deep engraving of metal. It would also be excellent for cutting. I'll let you know what a new one costs after I get quotes back. The price may be worth it though, as they last for 50,000 to 100,000 hours versus 1,000 hours for a CO2 laser.
November 10, 2013 03:43PM
i am interest to build this H-Bot type
do you BOM or especially rods/conduit length?
edit: found it in wiki
thanks,
Edited 1 time(s). Last edit at 11/10/2013 04:15PM by augus.
