How hot does the underside of the reprap heatbed get?
Posted by engstrom0304
August 20, 2013 06:44AM
Hey guys,
I'm designing a 3d printer and will be using the reprap heatbed mk3. I was just wondering if the underside gets as hot as the top of the heatbed?
Thanks
Tim
Re: How hot does the underside of the reprap heatbed get?
September 04, 2013 02:58PM
It definitely gets as hot, actually it gets hotter because the underside is the side that has the traces which generate the heat. Also be careful of what you mount the heated bed on, we tried an aluminum plate for our first mount which quickly became a giant heat sink eye rolling smiley. Hope that helps.
Through self sustaining actions comes freedom
DIY Tech Shop
September 04, 2013 04:46PM
also be sure anything you put on the bottom side is not bolted, and is loose, like fiberglass insulation would work ok. you don't want the bed to crack from thermal expansion from whatever you use on the bottom of the heated bed to protect below it.
