is there any reason why you couldn't make a good pcb with just solder paste? like if you simply toke a piece of plastic and drew your circuit with solder paste?
what I'm thinking is, if we could make pcb's with solder paste, you simply print a plastic board with tracks for the solder paste, set the component on top of it then throw it in an oven. does the plastic melt before solder? this would obviously be wastefull of material but it would easily give us the ability to make pcb's, especially since we have an easy paste extruder.
