How about air bearings made of plastic?
August 20, 2013 10:09AM
Still working on my first own printer I'm wondering, if it shouldn't be possible to print bearings working with compressed air.
While the surface quality of the inner side of the bearing is less important, compared to metal-bearings, it should be possible to e.g. drill the inner part to the correct diameter.
I'm thinking about that because of the LM8UU-bearings, which are either expensive or lousy in quality.
Compressed air bearings are not that new (common for precision machines), but I wonder if they, for our purposes, could be printed.
Here's a short video about the technology: [www.youtube.com]
Re: How about air bearings made of plastic?
August 20, 2013 04:20PM
It's possible, but I do we have any need for the capabilities such as high speed / high load bearing that fluid bearings offer? It would add more complexity and vitamin count for what benefit?
Still I would like to see it done. It should be very easy to design and mock up, though I don't have an air compressor at the moment to power it... hmm.
August 21, 2013 03:32AM
> benefit?
I try to reduce the vitamn count, not to raise it. The (printed) compressor raises the vitamin count would allow to replace the bearings and, more important, reduce the runtime costs that abrasion would cause over time. That's the idea.
> it... hmm.
I'm thinking of a small printed compressor. Souldn't be too complicated.
August 21, 2013 05:15AM
Uh, then you have this compressor running all the time. Might be a quite noisy experience. Also it's probably a challenge on its own to design a printed compressor which survives more than a few hours.
What's wrong with simple, plain old bushings? The better ones from IGUS or even printed ones? Especially with printed ones I see quite some room for improvements over the current technology.
August 21, 2013 06:48AM
> hours.
Maybe. It's a challenge, of course. Wouldn't be interesting otherwhise.
It's a question of how much pressure is needed. Think about compressors for aquariums. They are very silent and quite simple constructions - not so powerful though.
On the other hand a wobble-compressor (which is silent too) with one or two pistons and blade valves can be printed quite easily and would be relatively powerful.
I've got an old two piston wobble-compressor here that can serve as a master.
There's not too much wrong about classic bearings, especially if they are printed. But abrasion is an issue, even for good bearings, while air bearings don't wear out.
August 21, 2013 03:06PM
RobertKuhlmann Wrote:
> the
> > benefit?
> > it... hmm.
A printed bushing doesn't require any vitamins, though. They will eventually wear out but with a well-tuned machine a printed PLA bushing can certainly run for some months of heavy use. I think Nylon would make a better bearing material, but I'm not certain if the Nylon formulations we have available for printing is optimized for wear or not.
August 22, 2013 08:30AM
I have tried nylon (taulman 618) as bushing material. I think it is safe to assume that it will last a rather long time: My test setup
August 22, 2013 08:56AM
If bushings wear out, they have to be made adjustable smiling smiley
@RobertKuhlmann: you're right, it depends on pressure and volume required. Have you any idea how much this would be?
