wonky hot end
Posted by pocketmoon
wonky hot end
August 22, 2013 04:52PM
My hot end is wonky. I've tried removing and refitting to no avail. I think the two small springs are causing the mis-alignment.
Anyone see this ?
Cheers
Rob J
Re: wonky hot end
August 22, 2013 08:52PM
The whole thing looks wobbly. Loose screws?
Re: wonky hot end
August 22, 2013 09:48PM
What does WONKY mean?
unsteady, shaky
awry, wrong
weird, whacked out, messed up, not working for no definable reason
What printer, type hot end, type of mech extruder, PLA, ABS.
What is hot end doing or not doing?
Did you mount it? Did you use instructions?
Anonymous User
Re: wonky hot end
August 22, 2013 10:31PM
It definitely looks misaligned. I don't know why you need springs on the extruder. Seems like it causes more problems than it fixes. It could be caused by misalignment in the tapping of your mounting block. I'm not very familiar with Bowden extruders so I can't be of much help here.
Re: wonky hot end
August 23, 2013 04:23AM
It's a RepRapPro Mono Medel and they are part of the build instructoins. They're in there to allow height adjustment of the HE when multiple HE's are installed. I only have one HE so have taken the springs out and the problem is solved.
