2 Extruders, one printer
August 28, 2013 09:58AM
Hi Everybody,
I want to know what is the function in GCode to jump from one extruder to an other in GCode file. I can't find it. Or, how do the printer to change extruder when printing!!!
Please help me!!
Think you!!
Re: 2 Extruders, one printer
August 28, 2013 10:27AM
[reprap.org]
T: Select Tool
Example: T1
Select extruder number 1 to build with.
The sequence followed is:
    Set the current extruder to its standby temperature specified by G10 (see above),
    Set the new extruder to its operating temperature specified by G10 and wait for all temperatures to stabilise,
    Apply any X, Y, Z offset for the new extruder specified by G10,
    Use the new extruder.
Selecting a non-existent tool (100, say) just does Step 1. above. That is to say it leaves all tools in their standby state. You can, of course, use the G10 command beforehand to set that standby temperature to anything you like.
If the Z value changes in the offsets and the head moves up, then the Z move is made before the X and Y moves. If Z moves down, X and Y are done first.
After a reset extruders will not start heating until they are selected. You can either put them all at their standby temperature by selecting them in turn, or leave them off so they only come on if/when you first use them. The M0, M1 and M112 commands turn them all off. You can, of course, turn them all off with the M1 command, then turn some back on again. Don't forget also to turn on the heated bed (if any) if you use that trick.
Extruder numbering starts at 0.
e.g. T0 or T1.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
August 28, 2013 10:31AM
Think you rhmorrison ,
OK, but where can I find this function?!
Regards
August 28, 2013 01:20PM
I can't found this code on Marlinmain.cpp!!
Is it normal?
August 28, 2013 02:09PM
Here [github.com] perhaps?
August 28, 2013 08:26PM
why do you need to know this, the modern slicers take care of this automatically. are you doing something else? something great?
August 29, 2013 05:09AM
Think You bobc!! I found it in Marlin_main!!
to jamesdanielv : No I just want to understand how the printer knows the changement of extruders!! And how it does it, because I want to use 2 extruders!!
