(Noob) Which hot end to buy ?? September 07, 2013 10:05AM |
Re: (Noob) Which hot end to buy ?? September 07, 2013 10:08AM |
Re: (Noob) Which hot end to buy ?? September 07, 2013 10:12AM |
Re: (Noob) Which hot end to buy ?? September 07, 2013 10:14AM |
Re: (Noob) Which hot end to buy ?? September 07, 2013 10:48AM |
Re: (Noob) Which hot end to buy ?? September 07, 2013 11:21AM |
Re: (Noob) Which hot end to buy ?? September 07, 2013 11:58AM |
Re: (Noob) Which hot end to buy ?? September 07, 2013 12:00PM |
Re: (Noob) Which hot end to buy ?? September 07, 2013 02:03PM |
Re: (Noob) Which hot end to buy ?? September 07, 2013 05:13PM |
Re: (Noob) Which hot end to buy ?? September 07, 2013 09:25PM |
Re: (Noob) Which hot end to buy ?? September 08, 2013 12:28AM |
Re: (Noob) Which hot end to buy ?? September 08, 2013 08:35PM |
Re: (Noob) Which hot end to buy ?? September 08, 2013 11:38PM |
Jerms.a320
I had no idea the j-head body was made of PEEK , I assumed it was metal!
Jerms.a320
Seeing that I'm a complete noob would it be better to get an all metal hot head ( I'm assuming its very difficult to damage those ) ?
Jerms.a320
are nylon prints any good ?
Re: (Noob) Which hot end to buy ?? September 09, 2013 09:21AM |
Re: (Noob) Which hot end to buy ?? September 09, 2013 09:45AM |
Re: (Noob) Which hot end to buy ?? September 09, 2013 02:53PM |
Admin Registered: 17 years ago Posts: 1,472 |
Re: (Noob) Which hot end to buy ?? September 09, 2013 06:54PM |
Jerms.a320
the wood fiber plastic sounds heaps cool !
Jerms.a320
( what does hth stand for ? )
Re: (Noob) Which hot end to buy ?? September 10, 2013 10:18AM |
Re: (Noob) Which hot end to buy ?? September 10, 2013 12:16PM |
jerms.
Jinx, on the 'E3D now finally shipping' thread about who installed the hot end then it got clogged after a little use. the fact that is requires the fan concerns me a bit
Re: (Noob) Which hot end to buy ?? September 11, 2013 01:31AM |
Re: (Noob) Which hot end to buy ?? September 11, 2013 06:58AM |
Re: (Noob) Which hot end to buy ?? September 11, 2013 07:22AM |
Re: (Noob) Which hot end to buy ?? September 11, 2013 08:26AM |
Re: (Noob) Which hot end to buy ?? September 11, 2013 11:52AM |
near impossible to damage the E3D " have to go out your way". by not allowing it cool down before turning the printer can be a real ball ache to remove the filament due to swelling created.Quote
so when this happened did it damage the hot end in any way?
If you didn't leave the fan on for cool down could it melt the plastic that the hot end attaches to?
Re: (Noob) Which hot end to buy ?? September 12, 2013 05:40AM |
Re: (Noob) Which hot end to buy ?? September 12, 2013 06:13AM |
no so far been seamless transition, just push in the filament in until you see a little fila come out the nozzle, tighten the idler an lower,Quote
With that method of simply changing the filament do you end up with noticeable joints from where you have raised and lowered the print head ?
I've not noticed any, and the way the idler is bolted makes it easy to change filaments, works really good,and paired with hobbed bolt been have great resultQuote
The is no disadvantage using the Greg's reloaded wade extruder is there? those gears look so much cooler !
Re: (Noob) Which hot end to buy ?? September 14, 2013 10:53PM |
